bad idle post number 27
So, after replacing the ICV, fuel filter, tightened all intake runner bolts, fixed other vacuum leaks, adjusted base idle per Porsche manual, replaced 02 sensor, The idle is much better all warmed up. But on a regular morning in SO CAL, it coughs, sputters and wants to die till i catch it with the peddle . After I blip the throttle a bit it will start to hold and warm up. Anyway, I got both the regular idle and the idle with pins in B and C to be about the same. But still bad morning warmup. Wife just told me I spend too much time on my car! Dang. Any thoughts on where most guys set the idle/air screw? I read that turning screw to the left allows more air and should help keep a steady warm up idle. Not there yet.
Old 03-28-2018, 07:54 PM
Ever do a compression and leakdown? Ever have a shop check the mixture setting?
206 637 4071
Old 03-28-2018, 08:22 PM
I have plans for my local P shop to check the mixture. Thanks. Just bummed.
Old 03-28-2018, 08:31 PM
Good to know the engine is sound before putting a lot of troubleshooting time and parts into it.
206 637 4071
Old 03-28-2018, 08:34 PM
I’m sure you are right. After I did the tune up it passed smog really great and ran well for two weeks. I just keep going back and checking if I did something wrong. It runs really well at speed. It is time for a pro I guess.
Old 03-28-2018, 08:43 PM
After a huge search I have found that many owners of 3.2 cars have this problem!
Old 03-28-2018, 10:22 PM
T77911S's Avatar
just tell your wife you COULD be out at a bar drinking, at least you are home.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-29-2018, 04:28 AM
