Super Moderator
cstreit's Avatar
Unhappy What was that "tink" noise?
So I'm manually rotating the engine while setting the cam timing and hear this "tink" noise... SOunded to me (and Souk) almost like a bolt letting go, but also the sound of something just lightly tapping one of the cylinder fins...
We checked all the bolts and found no issues, but is there something I missed? Valves and the 1 & 4 intake rockers are intact...
I'M FREEKIN OUT MAN!
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-22-2003, 04:07 PM
a ring letting go of the cylinder wall? new motor?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 02-22-2003, 04:13 PM
Super Moderator
cstreit's Avatar
A ring letting go? You mean like one breaking? Would it sound so obvious?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-22-2003, 04:15 PM
not breaking. just stuck to the cylinder wall.
Old 02-22-2003, 04:51 PM
Somewhere in the Midwest
MotoSook's Avatar
tryan, can a ring that was caught create a loud enough "tink", through the cyclinder wall? Chris and I probably spent close to a hour looking for anything that might have poped off or come loose. It was scary.
Everything rotated fine, no unusual drag on the crank.
I thought maybe a ring snapped (cracked), but then Chris didn't think it would create such a noise on the outside.
Old 02-23-2003, 07:06 AM
Cool
I've read about brand new head studs snapping and flying into the wall
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-23-2003, 07:10 AM
MotoSook's Avatar
Ron, that was the first thought we had, but it wasn't very loud. Chris has 993 studs that are suppose to be the best these days, and we checked them all after the incident. It sounded like a small bolt/stud snapping under compression, but we checked all the heads/bolts. Chris may be in the garage hunting for something right now.
Old 02-23-2003, 07:14 AM
Senior Member
Doug Zielke's Avatar
It was documented by Bruce Anderson, in Excellence Tech Notes 2.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 02-23-2003, 07:37 AM
Cool
then only a wild guess of an air defelector snapping into place.. I guess asking a pro who does plenty of rebuilds might help.. I know that Wayne has routine contact with one of the best in the country.............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-23-2003, 07:40 AM
Super Moderator
cstreit's Avatar
ROn... Might have been...
I'm not gonna worry about it at this point, went over it with a fine tooth comb and found nothing... I think it was one of the above, but I doubt it was something internal, as it sounded to clear, and not muffled like a ring might.
Head stud was my first thought, but I checked them all...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-23-2003, 08:05 AM
Did you do any work on the valve springs? Is everything correct with the timing chain system? Jim
Old 02-23-2003, 08:15 AM
Super Moderator
cstreit's Avatar
Valve springs are new. All intact and not cracked that I can see... I found some metal shavings that I though "OH NO, THE SPROCKET IS OUT OF ALIGNMENT!" but checked that and it's fine. Turns out that the cam sprocket holding tool was too tight and was loosing little shavings as I tapped it on... Cleaned it, removed the whole cam box , gears, etc and cleaned them all good. No bits anywhere now.. No noises either. Motor turns good.
Still no source of "ting" just moving ahead...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-23-2003, 05:22 PM
Navin Johnson
TimT's Avatar
Chirs you mentioned in a previous correspondence about ow hard it should be to turn an engine over by hand..
Well I never have measured the torque manually, remember though the engine is as new is it will ever be.
I would be worried if the engine were easy to turn over, or if it didnt turn over evenly..
'69 911 GT-5
'75 914 GT-3
and others
Old 02-23-2003, 05:29 PM
Super Moderator
cstreit's Avatar
Tim,
Well it's not "easy", seems a bit harder to turn over than a broken in motor from what I remember. You can definitely feel the difference in the effort required when a valve starts getting compressed by the cam.
I think it's fine... Just worrying about nothing as usual...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-23-2003, 05:31 PM
If you replaced the springs then one could have been slightly unseated and then snapped into place when it was more fully compressed as you turned the engine over. Hope all goes well. Jim
Old 02-23-2003, 05:58 PM
Senior Member
Superman's Avatar
I agree with Jim. Sounds like something settled.
Mocha 1978 911SC. "Coco"
Old 02-23-2003, 06:18 PM
Super Moderator
cstreit's Avatar
Funny that you would say that Jim, because that's what I had been thinking... (But "settling" sounded too easy top me at the time). It really did sound like the exact tone a bit of metal bouncing off a head fin makes. We were able to replicate it by lightly tapping a wrench on one of the fins...
Though I could not find the cause, I'm not going to tear down the engine...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-23-2003, 06:44 PM
