witt
A/C compressor
In order to work on the right side inside the engine compartment I like to get the A/C compressor out of the way without disconnecting the lines to get some more elbow room. I am planning an oil and filter change, installing new sparkplugs and engine lid strut. I have done that kind of work on other 911s before, but never on A/C equipped cars.
Is this wishful thinking or can it be done and has it been done ? any helpful advise would be greatly appreciated.
The car is a 1988 Carrera Cabriolet.
CHEERS !
WITT !
Old 04-17-2018, 05:52 PM
rokemester's Avatar
I've not done it myself, but I've seen numerous repair pics. Where the compressor is placed off to the side on a thick blanket hoses connected. Done all the time.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 04-17-2018, 06:06 PM
1) Towel over the fender
2) Roll compressor over as far as possible
3) bungie cord to the fender lip or tire to hold it in place, or it will try to flop back into the engine compartment.
That will get in the way of the oil filter, and it doesn't really make a whole lot more room getting to the spark plugs...
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-17-2018, 08:31 PM
kuehl's Avatar
I've done work on the RH side many times without moving the compressor.
But if you wish to do so be careful not to put too much strain on the hose fittings,
you might have enough hose to move the compressor over to the left and tight it down
on top of some padding.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 04-18-2018, 04:19 AM
MBAtarga's Avatar
If you want to spend a little money, get you one of these: (Mfr is Colgan)
Mark
'83 SC Targa - since 5/5/2001
Old 04-18-2018, 05:40 AM
furniture blanket worked great for me. Don't forget the disconnect the electrical connection to compressor (I think it's for the clutch)
1983 911SC
2005 911S
Old 04-18-2018, 07:15 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Charlie,
Do you still sell the evap to comp line and comp to the lid condenser line a wee bit longer so the flop back risk is reduced if you lay the compressor on the fender?
Just for a data point.
1981 911SC Targa
Old 04-18-2018, 08:27 AM
