engine serial number
can someone be so kind to decipher the model number these two blocks are connected to?
i believe they are early 70's or late 60's one is 3451403, and the other is 6196276. i would appreciate it greatly.
Old 04-06-2018, 01:32 PM
6196276 decodes to a 1969 911T, US model, Karmann coupe engine. Type 901/16, 110 hp.
Cannot find 3451403 in my source, but the number sequence, begining with a 3, indicates a 1968, but if it was, the third digit should be 8, not 5. Are you certain the number is correct? If it was a typo and the number was 6451403, then it's a 75 US Carrera (same as 911 S.). If not, I'm stumped, but djpateman will probably know.
From 1969 on, the engine numbers started with 6, and before 1968 the numbers began with 9. The initial number, 3 in your serial number, indicates a 130hp engine. If it was a 2, it would be 110hp, and if was a 4, a 160hp engine. That's all I can decipher from my source.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-06-2018, 05:40 PM
Thank you for the reply. I tried to post the picture of it so you might be able to determine the numbers better. There are 7 numbers listed. I am absolutely certain about the 3, 4, (the 3rd number MIGHT be a 6?, pretty sure it is NOT an 8- thought at first blush it was a 5), am also certain about the balance- 1403. I hope that this helps! I appreciate your help on this.
All the Best,
Tom
Old 04-16-2018, 09:10 AM
All the Best,
Tom
Thanks for the update.
Still, it was only engines produced in 1968 that began with the sequence you posted and, therefore, the third digit has to be an 8. This, according to my usual source but I haven't been able to find any other source that identifies a 345XXXX engine. If you are certain the third digit is not 8, then I'm stumped.
L.J.
Old 04-16-2018, 09:48 AM
Hilbilly Deluxe
emcon5's Avatar
82 911SC Coupe
GTI Cup #43
Old 04-16-2018, 01:48 PM
thank you all very much for the help- I appreciate it greatly
Old 04-18-2018, 11:06 AM
If the 3rd digit was an 8- it would still be a 911T then correct?
thank you again
Old 04-18-2018, 11:12 AM
thank you again
No.
For 1968 only, the first digit determined the engine designation. "2" would have identified a "T", 110 hp type 901/03. You posted "3", so that decodes to a 130hp of several types that fit different models including L. A "4" would be an "S".
Can you post the type numbers? That might help narrow things down.
Even if the third digit is an 8, putting the engine number in the proper year, the second digit, the 4, is not identifiable from any source I can locate.
Is it possible for you to post a picture of the serial number?
L.J.
Old 04-18-2018, 05:42 PM
http://forums.pelicanparts.com/images/editor/createlink.gif
Old 05-08-2018, 12:06 PM
photo of serial number
Old 05-08-2018, 12:13 PM
newbie on posting the photo- went to "click here to upload photos" picture DID appear in that area......
Old 05-08-2018, 12:16 PM
New-ish 911SC Targa Owner
pampadori's Avatar
That "click here to upload photos" function leaves some things desired. Don't do the drag and drop. Instead, use the grey buttons to find the file and then upload it:
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 05-08-2018, 12:29 PM
pampadori's Avatar
@emcon5 is that handy chart missing some serial numbers that start with 677? mine is 6770540 and i can't find it there. Thought it was a '77 930 case and a type 930/52.
Old 05-08-2018, 12:32 PM
