ADDvanced's Avatar
LEDs still generate lots of heat, focused on the back of the bulb area.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 05-15-2018, 06:47 AM
Banned but not out, yet..
RSBob's Avatar
Originally Posted by Koizumi View Post
Isn’t one of the issues with our foglight housings: heat?
Every HID conversion I’ve done have run hot! 35w is even hot. Now it’s nothing as hot as HIR bulbs but...
I’m looking for non-ballast installs. No HIDs. Cooler LED bulbs would be ideal for me. Just for DRL purposes. The fogs for fogsakes are not vey good to begin with
I run my fogs tilted up a bit as DRLs and they are on for hours at a time. Heat has never been an issue. Used at the factory angle As fog lights they are Perhaps better than nothing. Also I have only replaced one bulb in two years. If changing to LEDs creates effective fog lights that would be a real benefit. If it is strictly for looking cool, go for it. I really don’t see any real problem here though.
Old 05-15-2018, 08:04 AM
Burnin' Rubber
Koizumi's Avatar
Problem: Fog light conversion to LED
Interesting, Gents.
My 35w H3 incandescents run pretty hot. Like I mentioned, I use ‘em as DRLs (so they’re on all the time on my daily driver 3.2).
Well, I welcome all mentioned alternatives or options. Just trying to stay cool
Cheers all
Btw: is there a way to tilt them upwards? It only appears to me that they can be adjusted sideways. I’m referring to stock fogs for ‘84-‘89 (which I think would be different than the SC fogs that hang as opposed to being inset into the valance for 84-89 cars).
Old 05-15-2018, 08:56 AM
LED Fog Lights
Hi everyone! I wanted to make my ‘85 3.2L more visible, so I converted my fogs to DRLs but had concerns about heat and also wanted LEDs to improve efficiency. I tried the H3 bulbs from Diode Dynamics but they were too dim for a DRL. I found these from www.hidkitpros.com by a company called Lumawerks. They’re even made in the US!
https://hidkitpros.com/shop/h3-high-power-led-bulb-30w-philips/
I had to do a little filing to turn them 90 degrees from their intended orientation so the LED points toward the reflector properly and am happy with them. At $60 a pair they’re not cheap but also not exorbitant. Good company, nice product, and they fit. You can see that the LED is positioned at the proper distance from the base to basically be where the filament in the halogen bulb was.
Good luck!
Old 04-25-2020, 06:52 AM
Bitte ein Bit
Good luck!
How are these working out for you? Visibility in the sunlight? I am running my stock fog lights as DRL and if you have any information on how you "modified" these (filing?) it would be much appreciated. Price seems fair and good to see made in USA.
Thanks for your original post -
Erik
Old 05-01-2020, 10:18 AM
Hey, thanks just gently filled the same shapes into the H3 flange at 90 degrees to their original location. Took ten minutes. Pardon the bad markup.
Old 05-01-2020, 01:47 PM
I haven’t driven the car yet this year due to the lockdown...but their brightness was similar to the halogens in my garage.
Harpo's Avatar
This is what SPOKE (Jerry) made for me
Old 05-01-2020, 05:29 PM
Harpo's Avatar
Yes, the heat sink fits inside.
Old 05-01-2020, 05:31 PM
Spoke’s LED fog lights
I’m also running Spoke’s custom LEDs for Fog lights in my ‘87 Carrera.
Bob G
‘87 Carrera Targa
‘74 914/4, much modified
Old 05-01-2020, 05:59 PM
Those are sweet. Didn’t know they existed. Does he still make / sell them?
Old 05-01-2020, 06:10 PM
Definitely
https://www.spokeworksled.com/911-led-solutions
Bob G
‘87 Carrera Targa
Old 05-01-2020, 06:14 PM
Synchro Joe's Avatar
Currently not shipping due to supplier issues related to COVID:
LED Brake Lights
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 05-01-2020, 06:40 PM
Those are definitely super cool. Bit more expensive than the bulbs I’m running...may try a set when the world starts turning again...
Thanks!
Old 05-01-2020, 07:45 PM
The 9 Store
[QUOTE=Rleog;10848274]I’m also running Spoke’s custom LEDs for Fog lights in my ‘87 Carrera.
I’m running Spoke’s fogs on my 914. Like all his other products, they are great. Any trouble, he’s a real person who responds promptly. I haven’t had any issues.
All used parts sold as is.
Old 05-01-2020, 08:17 PM
I try to do likewise...Good to hear from you again Mark!
Old 05-01-2020, 08:26 PM
spoke's Avatar
LED Brake Lights
I got an email yesterday saying the supplier (for the heatsinks) can now fill all orders although there is likely a backlog with military/essential businesses getting preferential treatment. When I get confirmation of shipping I'll remove the "out of stock" condition on the foglights.
Find Spoke's LED Products:
Old 05-01-2020, 08:33 PM
Tags
8t9 , anniversary 911 , bryan , voxster
