Entire DME is en route to Ingo just up Hwy 1 a bit...Thanks to all who connected us...
rick2, what do you do in the situation where harness wires are cracked? Sometimes it seems like a simple wire-wiggle solves a problem...Eventually, as said, it bites ya in the butt, and you're gettin' a tow... |
While waiting on Ingo to inspect the DME, I thought I would ask the collective here about these mystery wires found in engine compartment;
1. First 2 were stuffed under fuse panel on left rear of engine bay. Just find any mates, but the one does match the connector of an 02 sensor... 2. These 2 are found back where harness comes into engine bay. Again, cannot even find potential mates. Thanks in advance! [IMG]/Users/aaronmiller/Desktop/DSCF3518.jpg[/IMG] /Users/aaronmiller/Desktop/DSCF3519.jpg[/IMG] |
whoops!
Here's the pics. ![]() ![]()
Member 911 Anonymous
Round one is O2Sensor
Brown and Red could be rear fog light wires, it was an option. 6 terminal socket/plug, not sure an 86-88 will chime in
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
2. I don’t recognize the female 6 pin connector. 3. Is there a connector going into the heater blower motor? If not someone may have bastardized the original connector for spades if they switched a seized blower motor to an aftermarket one.
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus Last edited by wrxnofx; 05-23-2018 at 08:32 PM.. |
O2 sensor is plugged into terminal coming from bunch including the harness...That's what's confusing - o2 sensor always has been plugged into that end, while the connector in question has been stuffed up under the fuse panel...hmmm.
good call on bastardized heater blower connection...must be something in that genre... |
