Particular revs problem
Hi,
My car starts fine and idles fine. Upshifting and downshifting is no problem. The only time I have problem is when I’m at a lift for example and rev the engine a little bit., 3k for example, on the way down the engine stalls. Starts right up no problem. What might be causing the engine to stall on the revs down? Thank you.
1974 911 coupe 4 speed |
Member 911 Anonymous
Sounds like a vacuum leak
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
