SEVENT9
Name this part!
Any idea what this part is (pictured). I have checked 101 and online (waiting for my Bently manual to arrive) and cannot figure it out. My worry is that gorilla tape wrapped around it.
Any ideas?
SEVENT9
'79 SC Black: My first 911 & my birth year!!
http://forums.pelicanparts.com/porsche-911-technical-forum/1000359-79-outlaw-build-thread.html
Old 05-23-2018, 12:43 PM
where exactly is that?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-23-2018, 12:44 PM
proporsche's Avatar
Hi, I assume your 911 is 1978-79..your part is part of the smog equipment- for the smog pump.Is your smog pump still in place?Most likely not so remove this valve and plug the rest of the system.
I do not see more from your pick...?
Just get rid of it...;-)but follow some online instructions ......
ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-23-2018, 12:48 PM
SEVENT9
Driver's side engine bay. You can see the gorilla tape in the pic below that should give a good sense of where it is. Sorry, I've had the car for a week, still finding my way around.
SEVENT9
Old 05-23-2018, 12:50 PM
proporsche's Avatar
the location is on left camshaft housing-the top is served the smog system for emissions back in the 1980`s
ivan
SEVENT9
ivan
Correct, yes - it's '79 and no need for emissions tests here in Canada. So I could yank it?
SEVENT9
SEVENT9
ivan
Ahhhh - which probably explains the empty bracket right next to it as well then. Pulling both of those would give a little more room in the bay.
Thanks Ivan!!
SEVENT9
Old 05-23-2018, 12:52 PM
proporsche's Avatar
yup..get rid of it ..Do you still have the x mass tree on the bottom of the engine..
this one.You can also remove it if you still have it in place..
these grey pipes
Old 05-23-2018, 12:54 PM
proporsche's Avatar
You have to get some nice Copper plugs for your heads ,where air injector are.
Here is the thing you should remove.
ivan
Old 05-23-2018, 01:05 PM
SEVENT9
ivan
Fantastic help - thanks Ivan!
SEVENT9
Old 05-23-2018, 01:07 PM
proporsche's Avatar
Any time.....
Old 05-23-2018, 01:11 PM
SEVENT9
Ivar - I am sorry, could you also help me with the blue hose. I have just found a split in it so it needs replacing (air patching if that is possible) and I am wondering is this could be the reason for my cold idle issues: CIS Guages - Are these any good?
My thanks again mate!
SEVENT9
Old 05-23-2018, 01:37 PM
Fleabit peanut monkey
Bob Kontak's Avatar
That is a beautiful diagram.
You must be drinking outstanding beer.
1981 911SC Targa
Old 05-23-2018, 01:43 PM
proporsche's Avatar
Bob ..never mind ,Rose out of Provence.FRANCE ..company )
the faculty..be specific which blue hose?On that link i am lost..
sorry, i go to bed now till manana...
Ivan
Old 05-23-2018, 01:51 PM
Bob Kontak's Avatar
Ivan
I love this guy. +1
1981 911SC Targa
Old 05-23-2018, 02:04 PM
proporsche's Avatar
Bob ,correction here is my poison....
Hôtel 5 étoiles en Provence | Château de Berne | Luxe & Art de vivre
Old 05-23-2018, 02:11 PM
SEVENT9
Ivan
lol - sorry Bob, it would help to point it out. I think I mean the distributer vacuum line. I read in a few threads its an emissions thing so wondering if I can pull that and cap it when I get around to pulling this stuff out.
SEVENT9
Old 05-23-2018, 02:31 PM
Bob Kontak's Avatar
It is a vacuum retard line, I am pretty sure. My 81 has both retard and advance but that is a different animal. The retard works at idle only. Once off idle the blue line is non functional as there is less vacuum in the intake.
Plug it with a golf tee. It will advance timing several degrees and the car will idle a little better. Plug it back in for emission testing if applicable.
1981 911SC Targa
Old 05-23-2018, 02:55 PM
Mark Salvetti's Avatar
Here are some photos of what you used to have.
In this photo, you are missing the air pump itself and the black twisty hose. The other part is the piece you have with the tape on it. It connects to the check valve that Ivan posted a photo of up above. The check valve sits in the engine tin, and if you remove it you will be left with an open hole. You want to seal that hole to prevent hot air from under the engine getting sucked into the engine compartment. I riveted a piece of aluminum over the hole.
The piping underneath the engine is connected to that check valve, and then it branches off to inject air into each cylinder at the exhaust ports. This is what the piping looks like, as well as one of the air injectors. In my case the injectors unscrewed easily from the heads. You can buy plugs for the air injector holes from Pelican (Part PEL-BRC-02). You have to cut the piping off unless you remove the heat exchangers, in which case you can remove the piping whole in case it is ever needed in the future:
Oh, one last thing. That part you have with the tape on it used to have a vacuum hose connected to it. Comes out of the air box to the left of the air filter. You want to make sure that line is plugged.
Good luck!
Mark
1979 911SC Targa
Old 05-23-2018, 07:13 PM
SEVENT9
This is all a HUGE help!! Thanks Mark!
SEVENT9
Old 05-23-2018, 08:10 PM
