Cool Engine dimensions for 3.0L SC
I知 building a manifold from scratch for a cis to efi conversion, and I知 wondering where I can find the dimensions for the center to center distance between the intake ports on a SC 3.0L engine.
There was an interesting article at: http://www.sdsefi.com/techinta.htm on fabricating an intake. If you click on the link at the very bottom you値l see another cool intake for a flat four.
My plan is to build velocity stacks straight up from the heads, and enclose the air horns inside a tube like the first example, but I want to put the throttle body at the end of the tube like the second example. I figure I値l build two manifolds with two independent throttle bodies, the same way as the Viper intake.
If anyone can help with dimensions, or where I can get them I will be grateful. My car is a daily driver, and with the rather cool weather right now it is hard for me to get accurate measurements needing all of my heating system in place.
TIA
GT911
81 911 SC
Old 02-25-2003, 08:27 PM
Anybody have a 3.2l intake not on their engine, that they can measure the center to center distance between ports?
GT911
81 911 SC
Old 02-26-2003, 01:49 PM
PMAC
Guest
Posts: n/a
How about ~ 11.8 cm center to center. Measured off the passenger side of a 3.2L manifold
Old 02-26-2003, 06:08 PM
Cool
How about ~ Thank you very much PMAC!!
I wonder if anyone knows of any blueprints anywhere, (that would anywhere this side of Stuttgart).
I would think the easiest blueprint to find would that of the crank. A blueprint of the crank would reveal an accurate distance between the centers of every other throw.
Don稚 reach for the little spec book, it痴 not in there.
Thanks again PMAC, I can start a scale drawing now.
GT911
81 911 SC
Old 02-26-2003, 08:50 PM
The center to center dimension between the intake ports would be the same as any of the following:
C to C of the exhaust ports.
A point on one cylinder head to same point of adjacent cylinder head.
C to C of sparkplugs.
Several points of symmetry under the intake or exhaust covers.
Pull an intake valve cover and measure away.
Old 02-27-2003, 02:56 PM
Thanks Brian.
I am aware of the many points that will equal the center to center distances for the intake ports.
I doubt I will get a better measurement than PMAC has already done for me, but I wonder why a blueprint is so elusive for the engine.
I'm working with 11.8cm, that PMAC provided, but a blueprint may reveal the real distance to be 11.78cm or maybe 11.82cm, a mm here or there could save a headache later in the fitting process.
With the several thousand members of this board I just figured someone might have some drawings in their personal archives.
GT911
81 911 SC
Old 02-27-2003, 05:00 PM
