LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
Harpo's Avatar
Thanks, added to the basket
Old 06-25-2018, 02:13 PM
UROParts's Avatar
Originally Posted by 47silver View Post
does it have the slot for the chrome for a 1975?
Indeed it does, the seal is the same for either black or chrome trim.
Originally Posted by Autoban View Post
My '86 Cab has the windshield antenna for the radio. Can I use your seal for this application? Does it have a slot/hole for the antenna cable to go through?
Juergen
Per our PET data, Porsche only made one seal, and didn't make a version specifically for cars with windshield antennas. Per Jesse16 below, the antenna wire is flat and is simply sandwiched against the seal toward the inside of the car. Thanks for the details Jesse!
Originally Posted by 3Ddesigns911 View Post
This is the picture I have that shows the antenna. The end of the wire with the connector was not properly attached (probably during the last install) and it was soldered back on and shrink wrapped.
Old 06-26-2018, 11:04 AM
Spiderman
Jesse16's Avatar
Nice Photo URO of antenna wire
My latest 2 windshields have that amber plastic covering a flat type wire coming out of the windshield. Seems to work just fine and eliminates the need to punch a hole at all in the seal. Flat wire just lays against the seal toward inside of car and then routes through the original hole to the froot/frunk. I like it, one less place to allow water to come inside.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 06-26-2018, 11:28 AM
PCA Member since 1988
Does anyone know if the URO seal can be installed without the metal trim? And can the trim be pressed in (carefully of course) later? The reason I ask, is I am about to install the windshield using the new style URO seal, but now I can't find the chrome trim that was floating around in my garage for years (and thorough one move), so I might have lost it. If I can get away without it, fine, and if I can install it later after I find it, or give up and buy a new pair, so much the better. The car is a 1973 911T with 3.0 engine. Thanks in advance.
Old 01-10-2019, 12:55 PM
toddu's Avatar
Having recently done the windshield (all windows actually), I would say not. The trim is really what holds the gasket in place, and necessary on the windshield more than any other (with the corners). I don't see how you could get it in after the fact. Takes a bit of pushing the "barb" in and finessing the gasket "out" to get it to seat properly.
Todd
'81 SC
Old 01-10-2019, 12:58 PM
Todd, thanks. Looks like I'll have to buy replacement trim.
Old 01-10-2019, 01:08 PM
47silver's Avatar
You will not be able to install it with the window installed.
Is it chrome or black? I have a black trim i can send to you.
Old 01-10-2019, 04:08 PM
Sounds like the URO seal is a go then.
Has anyone installed one, without the metal trim at all? Will it seal?
Old 09-18-2019, 03:13 AM
UROParts's Avatar
It's a good idea to use the trim. The trim anchor "hook" fills a channel in the seal, which helps maintain its structure.
Found a couple install videos that may be helpful.
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2
Old 09-18-2019, 10:57 AM
proporsche's Avatar
do you have a windshield seal for a window without the alu trims?For 1987 - 92 windshield?
thanx
Ivan
1985 911 with original 501 645 miles...807 319 km
Old 09-18-2019, 11:20 AM
UROParts's Avatar
thanx
Ivan
Thanks for the inquiry Ivan, unfortunately we don't offer windshield seal 964 541 225 00. We've been considering doing it, but haven't pulled the trigger.
Old 09-18-2019, 01:41 PM
proporsche's Avatar
ok i c ..i could be your guinea pick one the trigger is pushed;-)
thnax
Ivan
Old 09-18-2019, 10:59 PM
a.k.a. G-man
Geronimo '74's Avatar
Am I the only one that thinks that those 3 extra millimeters make a significant visual difference?
I am not sure if I like how the extra width looks.
Or are the pictures deceiving me?
Old 09-19-2019, 08:18 AM
FYI, Katie at Pelican is still under the impression that the aftermarket seals aren't worth buying.
Old 09-19-2019, 09:45 AM
I also asked Rock Auto if their stock was new or made before 2018, and they couldn't answer me, so I called Uro, and asked if Rock Auto's stock on this part was new or old, and they said they couldn't tell, and the guy on the phone didn't have a good idea of what this part did because he told me I could return it if it leaked, and I told him if it leaked it'd ruin my interior and cause rust, and he said , and I quote, 'Then don't buy it'. I hung up at that point.
Old 09-19-2019, 10:33 AM
UROParts's Avatar
We drop-ship for R*** A***, so nearly all URO items ordered from them come straight from our warehouse in Southern California, and would certainly be the latest stock. All of our sales personnel know this.
Edit: A personal message has been sent to you Coblue, please check your inbox.
Old 09-19-2019, 10:56 AM
Call was at about 11:25 AM or so California time.
He did mention that they should have the latest, but R.A. and he both said there was no way to be sure.
Originally Posted by UROParts View Post
We drop-ship for R*** A***, so nearly all URO items ordered from them come straight from our warehouse in Southern California, and would most certainly be the latest stock. All of our sales personnel know this.
Edit: Checking with our salespeople about your call this morning, standby.
Old 09-19-2019, 11:20 AM
7783911's Avatar
URO...
does the uro line have a proven seal for the 77 targa rear window?
Old 09-21-2019, 06:22 AM
Coblue, I believe R0ck Auto is more akin to Amazon than anything else... essentially they broker the sale and an actual auto parts seller fulfils the orders (with RA taking a vig). Excellent business model! John
Old 09-21-2019, 07:19 AM
Ginger77's Avatar
My '77 received a new front windshield seal in 2017 of $150 according to the receipt. So given the price it's probably a Porsche product but the seal doesn't seat very well in the upper left corner. I suspect this is one of the reasons for my road noise in the cabin. While driving you can clearly hear wind entering the car from the windshield.
Replacement of this seal is no fun job. But would the new Uro seal cure this road noise in your opinion?
Diederick
I drive a US import 1977 911. Formerly owned by a woman in California named Ginger - which appropriately led to the nickname.
IG: no dedicated account but photos are posted with #ginger77
Old 09-21-2019, 09:03 AM
