I had a LOT of trouble replacing the rear seal using the factory gasket but the front was a breeze, also with factory gasket. I think the trick is to get the metal trim bent into correct position.
Ginger
Need to use a plastic or wooden plinth to push rubber out to the corners do a search for fitting porsche windshield seal |
So the URO front window seal is redesigned and maybe pretty good- what about the coupe rear window seal? URO version has one star on pelican, is it still terrible or has it been improved?
Sent from my Nokia 7.1 using Tapatalk |
^ Our rear window seal for the coupe (911 545 225 00) hasn't been changed since it was released about five years ago. It's on the to-do list for redevelopment however, due to the feedback you mentioned.
Thanks for the update!
^ The softer version should be in our warehouse sometime in March, and will have code "7524" or higher in small print on the label.
Our current stock has code "7389", which could actually be the softer version, but can't confirm it due to close timing between the engineering change and that production run. |
Üro,
would you have a front windshield seal for the 964 with the same qualities as the 911 version? |
^ Sorry, we haven't done the 964 seal yet, though essentially it’s the same seal without the provisions for exterior molding. It's on the to-do list.
Good. Please get on it. Many 964 owners will be thankful, I the first.
Good thing about the wider lip is, you don't see the edge where'd been repainted :-))
I bought one of the URO windshield seals from Pelican in Oct (2019) and just got around to installing it last week. When I opened the bag, I noticed a couple of very large tears or gashes in the outer portion of the seal. Bummed as I should have checked the item initially when I ordered it. Pelican had great customer relations and sent me out a replacement immediately. When I opened the new seal, it also had 2-3 small tears on the inner part of the seal. WTH I thought, but I'd give it a chance as I thought the tears wouldn't be visible when the seal was installed and they shouldn't affect the installation. Was I wrong.... When the string passed over one of the small tears, the string tore a large section of the seal. I decided to try and finish installing the seal just for grins. The URO did not fit well at all on my car and I ended up having open sections in the corners much larger than my previous seal. I think I'll try a "factory" Porsche windshield seal next. And yes, I've installed a few of these seals in the past. I'm not convinced aftermarket is much of a cost savings when you have to go through this much nonsense.
Hi Doug, if you had openings at the corners, the seal has to be the old version that has the same lip width as OEM.
PM us your order details and shipping address, and we'll send you our new version with the wider outer lip. Thanks! |
I recently used one of these updated seals and was very impressed
the extra material really helps fill the corner which in my experience is always a PIA I'd say 2 big thumbs up |
964 vs 911 front windshield seal
Slightly off topic
Is the 964 seal the same as the 911 seal except for the trim? So if I don't need/want the trim I could use the 964 seal on my 1974? Same for the rear? Thanks David |
The 964 windshield is slightly bigger than a 911 so the seal is different.
But according to "aftermarket glass people" the window openings in the body are the same on all 911s (911, 964, 993). However I'm not sure how true this is because I've never confirmed it for myself and people have had issues fitting a 964 windshield and seal in a G Model 911. (It doesn't fit - too big) What people have done with success is the installation of the 993 windshield and its glue in seals on a G Model 911. This works well and I've seen it first hand. Very neat and tidy. What I would like to try is a G Model 911 windshield using a 964 seal in a G Model 911. It may be a bit loose but a bit of sealant (non hardening) in the right places may fix the problem. And just for info... A friend in the local Porsche club has been running an SC with just the glass, rubber seal and trim. He uses no sealant at all on any on his fixed windows and has never had an issue but his car isn't daily driven and rarely if ever sees rain. This subject has been talked about a lot here. Searching is a good idea but it can get confusing. |
http://forums.pelicanparts.com/uploa...1582570809.jpg I think a lot of people that DIY their seals use no sealant because it's not something that is specifically required. But it does help. You can use the non-hardening material like 3M glazing compound. It fills the voids where the seal doesn't fully occupy the frame opening and it doesn't take much at all. We're talking about barely a couple of full squeezes of the caulk tube gun when you go around the entire perimeter of the seal. The places where the sealant is most used is in the corners. Along the straight sections of the window frame, you can't really put much sealant in there because the gap between the bulk of the seal and the lip is very small. Anything you inject in there just oozes out when you press on the seal lip. I recommend masking around the edge of the seal lip after you have the windshield seated in place. Makes for faster cleanup of the sealant than progressively wiping it away with a cloth My next windshield install on the '86 911 is going to be a 964 glass and 964 seal. I had intended on doing this with my racecar project but that never came together and is now in the process of being parted out. I was hoping to find a cheap/used 964 windshield locally for a test fit but never came across one. However there have been numerous mentions here over the years of using the 964 glass and seal w/success. The 964 seal with 911 glass was often mentioned as not working because it was too loose of a fit. When I did my first windshield job on my former '87 in 2003, I tried the 964 seal with my existing 911 windshield (not Sigla original, Pilkington Sigla replacement) and the fit of the seal around the glass with it lying on the floor (on a blanket) was so loose that I knew right away there was no way the 964 seal + 911 windshield combo was going to work. So I used a typical 911 seal with the same Pilkington windshield and it's still performing fine with the new owner today in 2020 who has become a very close friend since 2014. He'd let me know if my install was going south http://forums.pelicanparts.com/porsche-911-technical-forum/68438-windshield-gasket-replace-86-964-style.html#post667578 Regarding the 964 glass and 964 seal combo, it should work in a G body car. I've seen the finished product in person but I did not see the assembly/installation. A longtime good friend of mine had me garage his '78 SC targa at my house while he was moving from IL to Detroit and he wanted me to help sell the car. It had what I believed was a 964 windshield and 964 seal and it fit nicely. But Jay didn't install it himself. He bought the car from a local friend of ours who bought it from member Paul Sopp pbs911 here on the forum. http://forums.pelicanparts.com/porsche-911-technical-forum/921267-trick-installing-964-front-rubber-windshield-seal-78-sc.html#post9572906 But it's not an absolute guarantee it will work. Some have tried the 964 glass and 964 seal and found that it was too big and they couldn't get the glass seated in the opening. Here's a thread with a few mentions of that http://forums.pelicanparts.com/porsche-911-technical-forum/864351-964-windshield-rubber-seal-earlier-car.html http://forums.pelicanparts.com/porsche-911-technical-forum/100874-964-windsheild-85-dont-do.html In researching what pbs911 did, his second attempt at it appears it is a 993 windshield with the 964 seal! http://forums.pelicanparts.com/porsche-911-technical-forum/64955-996-windshield-78sc-yes-you-can.html http://forums.pelicanparts.com/porsche-911-technical-forum/71981-up-grade-wshield-opnions.html I would never think to try a 993 windshield with 964 seal because the 993 windshield is a completely different sealing process with actual glue/urethane and multiple separate trim pieces. It's a nice setup and I know guys have done the complete 993 system in their G body cars with success. So as you can see, when you go off the radar and use later 964 pieces, success varies. So does the quality of glass. Not all glass is the same, so they plays into it as well. Crazy............. |
If I order this part: 911 541 225 03 will this be the very latest URO front screen rubber seal ?
Out of curiosity what was the old URO part number? |
The part number hasn't changed, but as of June 2019 Dmitry said Pelican is shipping the new version.
| All times are GMT -8. The time now is 08:13 PM. |
