Twin plug what if question
I'm helping my friend commission his 930 on Megasquirt. We're having the usual teething problems but that is expected. He is running a twin plug setup with COP's on each. My question is: what if one coil on a twin plug setup goes south? It would still run but now just on single plug on that cylinder. I'm thinking on a boosted engine putting out lots of HP, the loss of one coil/plug would not be good. What are your thoughts of loss of one plug?
And for those that like to worry, short of testing each coil every day, you really have no way of knowing both coils are working. That would bug me.
1986 Targa Guards Red 2021 MT09 SP Last edited by brighton911; 06-12-2018 at 04:49 PM.. |
You would potentially see a lean spike when that cylinder's exhaust made it to the oxygen sensor, losing a plug would result in less complete combustion and would indicate as lean on a wideband. That would be about the only way I would see being able to identify a dropped plug on a cylinder.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Location: behind the redwood curtain, (humboldt county) california
wouldn't a dropped plug show rich??
If the mixture isn't completely burned, wouldn't the o2 sensor show rich??
Do the ECU's have the equivalent of a "check engine light" that would store a code?? When I worked in a dealership at the onset of computer tailoring of the last bit of mixture, (GM CCC), we would joke about putting black tape over the check engine light - but never did. Seriously, doesn't the ecu have a way of indicating a problem, short of hooking up a laptop?? It would seem helpful to the driver if the O2 sensor went out of spec, alerting her to a likely problem. chris |
Uncertifiable!!!
![]() Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 06-13-2018 at 04:24 AM.. |
I’ve read quite a bit about this on other threads when using twinned boxes
I haven’t looked but I think Henry smidt is one of the contributors if you want to search in his name or msd twin plug
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
If you add a dual AFR display on your dash you can catch the problem before it gets too hot.
Mark Jung Bend, OR MFI Werks.com |
Chain fence eating turbo
You’d lose power as now your timing is retarded
I've got twin plugs and twin MSD's on my 81 3.0L in my 72 911. I put a switch, in the engine compartment, that turns one MSD off to check that they are both working. It works like doing the Mag Check on an airplane before takeoff.
Kent Olsen 72 911 SCT upgraded 3.0L McMinnville, Ore |
Here is the factory RSR solution for twin plug switches (looks like carried over from the 550 spyder of 1955)
Well there ya go, the "problem" has already been solved (of course). Yes, I like that idea of switches to cut out coil sets as a check. Thanks for everyone's inputs.
1986 Targa Guards Red 2021 MT09 SP |
Functionista
Interesting side fact. When a 964 comes in for service a guy is supposed to pull each coil quick disconnect off one by one to check each circuit’s ability to run the car...
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
The other option discussed in the other thread is to run two coils off just one box
( much discussion ensued)
