Sam
What is this thing, part 2
Piggy backing off Gretz, can anyone (Dennis?) identify the small square black box attached to the driver side wheel well area in the frunk of my US version 82 911SC?
I came across the box as I began installing Fred Cook's fuse panel update (only took me four years to get around to it). In doing that project, I have had to repair some old wiring, add sections, etc, which I expected would be the case. I am also cleaning out the last wires from an aftermarket alarm system (aka the nightmare). Being a novice wiring diagram reader, I cannot find the mystery box in the Bentley Manual, but I am sure someone will tell me it is there.
Any help is greatly appreciated.
Sam
Old 06-13-2018, 04:22 PM
Still here
pmax's Avatar
Box with the X ?
Rev limiter.
Old 06-13-2018, 04:31 PM
Peter Zimmermann's Avatar
That box (the one with the "X" and no visible numbers), if memory serves me, has something to do with the fuel pump/rev limiter circuitry.
Keep the Shiny Side UP!
Pete Z.
Old 06-13-2018, 04:36 PM
Sam
Thank you both. You California guys have all the answers.
And Dr. Z., nice to hear from you!
Best,
Sam
Old 06-13-2018, 04:44 PM
I looked for info on rev limiter on the Carrera 3.2 Owners Manual and did not find it. Did I miss it? Where is it discussed in the Owners Manual?
Old 06-21-2018, 08:49 PM
Still here
pmax's Avatar
I believe the Motronic ECU provides that function.
Old 06-21-2018, 10:02 PM
Right, of course. I found a reference to a 'speed limiting governor' on page 32 of the '86 Carrera Owners Manual. I found no other mention.
Old 06-21-2018, 10:06 PM
Diss Member
Quicksilver's Avatar
The 86 owners manual has no bearing on this.
1984 and later Carreras are Motronic DME computer controlled.
1973.5 thru 1983 are CIS K-Jetronic controlled.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-22-2018, 02:58 PM
