Bristol Cities
Guvnor's Avatar
Hi-Torque Starter Upgrade Question
Hey guys- I’m looking at getting the WOS Performance hi-torque starter but it seems to only have one terminal for the ignition wire to connect to. The SC with CIS needs two terminals with the second sending power (not sure on voltage) to the cold start injector during cranking.
Is there an easy way to wire up a jumper for this or should I stick with the OEM type starter?
1983 911SC
Old 06-13-2018, 09:59 PM
Hi Guvnor.
You just connect both of the thin cables to the same point on the leight weight starter.
I have done this my self for just a couple of days ago, its easy to do and I am very happy with the result. Now I can use a much ligther starter battery also, mine now 44Ah and 350 CCA.
I saved in total approx 20lb !!
See this article:
https://www.pelicanparts.com/techarticles/911_starter_install/911_starter_install.htm
Old 06-14-2018, 01:14 AM
Mark Salvetti's Avatar
You can buy piggybacked spade terminals so you can mount both wires. See post 23 in this thread:
high torque starter install
Mark
1979 911SC Targa
Old 06-14-2018, 03:52 AM
Bristol Cities
Guvnor's Avatar
Thank you gents! Ordered a pack of 25 from Amazon for probably less than one would cost at the local auto parts store.
http://Ancor 210613 Marine Grade Electrical Double Male-Female Adapter (25-Pack) https://www.amazon.com/dp/B000NI5D92/ref=cm_sw_r_cp_tai_i_v4MiBbHN6TD0R
1983 911SC
Old 06-14-2018, 05:37 AM
How are you liking the starter motor? did you get the WOS ?
Looking to get one for my 911.. cannot find much reference to them anywhere...
Old 05-03-2019, 03:46 PM
