Jwest shifter binding
I recently purchased a used rennshift for my 86 915. It seems when i tighten the rod bracket the shifter binds. I've tried placing the bracket both on top of the tunnel and under the tunnel. Seems either way, it puts the bracket at an angle. If i leave the rod bracket disconnected everything shifts fine. WHAT AM I MISSING??
I appreciate any thoughts.
Old 06-17-2018, 04:52 AM
Think i need some sort of spacer to keep the rod bracket in line?
Old 06-17-2018, 06:14 AM
I am my 911's PO
'78 SC's Avatar
The guide bracket mounts directly to the bottom of the shifter and not to the chassis tunnel.
Here's the installation sheet.
https://www.jwesteng.com/shop/instructions/RennShift_web_instructions.pdf
1978 SC - original owner
1983 SC - D stock "rescue" track car
DECEASED 2015 Cayenne Diesel (rear ended by distracted driver)
2017 Macan (happy wife...)
2016 Cayenne Turbo - tow vehicle and daily drive
Old 06-17-2018, 08:04 AM
Can you post some pictures?
1986 911 Grand Prix White
Old 06-17-2018, 09:05 AM
Thanks for the feedback.
Think i figured the problem out. It appears that the shifter base had a small spacer attached to the bottom to relocate the rod bracket into the tunnel, instead of mounting on the top of the tunnel.
I glued 2, 1/2 brass bushings to the bottom of the base and installed with m6 1.00Χ40 bolts. The only issue is the bolts are not cap style, they are a Phillips head. Not sure how important the cap style bolts are for proper operation, but I'm trying to locate a few now and will replace them.
Thanks Steve
Old 06-17-2018, 09:26 AM
78 sc, you're absolutely right, but it needs a spacer or it pulls the rod up instead of staying horizontal.. thanks for the help..Steve
Old 06-17-2018, 09:29 AM
I am my 911's PO
'78 SC's Avatar
Seems like spacing the guide bushing downward would prevent the bushing on the lower end of the shift lever from seating properly in the socket on the end of the shift rod.
How do we know the rod has to be horizontal?
Old 06-17-2018, 10:13 AM
It didn't place it downward. It kept it inline to be straight.
Even with the bracket bolts finger tight right against the jwest base put the rod at an upward angle, which bound up the plastic rod bushing. Setting the rod bracket about 1/2 off the base stopped all the binding.
Apparently the new jwest bases don't require a spacer and the rod bracket stays on top of the tunnel.
It seems to be working properly, but cant drive it until i put my starter back in.
Old 06-17-2018, 10:29 AM
Just went to look at the cup bushing. There's less then an 1/8" of the bushing sticking out of the cup. I'm thinking that's pretty normal? It seemed that the jwest shifter lever might be just a touch longer than the factory lever!?
Old 06-17-2018, 10:36 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
The older JWest shifters came with a small aluminum spacer to space the rod bushing down ~8mm (if my memory serves). The newer ones don't need it. Did you get that piece with your used shift console? Do you need measurements? I will be home tomorrow and can get dimensions for you.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 06-25-2018, 03:25 PM
RDM, i bought the shifter used and it didn't have the spacer. Ultimately i used a few 1/2" brass bushings to relocate the rod bracket. As of now the shifting is pretty good, but hoping to get it perfect with a little fiddling with the coupler.
Thanks for the offer though, its much appreciated.
Old 06-25-2018, 05:30 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
For the sake of future readers with this problem, the spacer is 10 x 20 x 40 mm and looks like this:
The green wire is not a part of the installation (of course).
Dru
Old 06-29-2018, 04:05 AM
