silver912e's Avatar
Question 912e cooling fan
Is the cooling fan on the 912E different from a '76 914 fan?
The fan on my 912E has a flat inside surface. The 914
fan that I bought to replace it has a surface that tapers
up (see picture). Did they ship the wrong fan, or did I order
the wrong thing?
Thanks.
Old 04-15-2003, 11:49 AM
eki912's Avatar
Went to garage to check. Mine seems to be flat.Or what I could see of it.I did not see anything pointing upwards as in your picture , the right hand side one.
e k i
Old 04-15-2003, 01:19 PM
WFBowen's Avatar
My guess is that the one on the right mounts directly with only the screws, while the one on the left is mounted by attaching the smog air-pump flange over it. The tapered one is probably earlier 914/vw without the pulley drive for the smog pump.
Bill
Old 04-15-2003, 08:07 PM
The one on the right is the early T-4 model. They went to the flat surface to accomodate the smog pump. I got a few. E-mail if you want one, $15 plus shipping.
67 912 2.0 Type 4 "Gumby"
94 968 Cabriolet
http://Gumby912.servebeer.com
Old 04-16-2003, 07:31 AM
