Is the cooling fan on the 912E different from a '76 914 fan?
The fan on my 912E has a flat inside surface. The 914 fan that I bought to replace it has a surface that tapers up (see picture). Did they ship the wrong fan, or did I order the wrong thing? Thanks.
Went to garage to check. Mine seems to be flat.Or what I could see of it.I did not see anything pointing upwards as in your picture , the right hand side one.
e k i |
My guess is that the one on the right mounts directly with only the screws, while the one on the left is mounted by attaching the smog air-pump flange over it. The tapered one is probably earlier 914/vw without the pulley drive for the smog pump.
Bill |
The one on the right is the early T-4 model. They went to the flat surface to accomodate the smog pump. I got a few. E-mail if you want one, $15 plus shipping.
