WEBER IDF 40 conversion help
68 912.. “Weber 40’s”
Just purchased a rennline Weber conversion, got it very close.. idles great.. after I put miles on it.. it loses idle, dies at lights.. stops signs ect. Will start up with a little throttle finesse and go. Current settings: 50 idle 125 main 200 air mixture screws one turn out Idle was set at 1000 rpm Thanks in advance! |
You'll probably need to adjust each idle screw separately for fastest/best idle. If that doesn't help much, definitely check your float levels and make sure the carbs are synced. If you're running a vacuum advance distributor, check that it is getting its vacuum from the correct carb source.
Bill |
