DStar5000's Avatar
Send a message via AIM to DStar5000
68 912 5 Speed, Angle Drive pin missing
Hi Guys and Gals!
I replaced a speedo cable thinking it was bad, only to find out
that the pin in the angle drive that sticks in the cable is missing.
I have looked high and low and can't find one for sale. All I can
come up with is buying a rebuilt angle drive unit for $49.95.
Surely, someone sells that pin by itself!
Don
Old 05-01-2014, 06:32 PM
VDO might have them, otherwise, never seen any parts. Usually the plug falls out and tapping a dime in will fix it. If'n you lost some of the parts. You would then just purchase a new one.
Old 05-02-2014, 09:33 AM
DStar5000's Avatar
The angle drive is some sort of hex arrangement and the speedo is a
slotted type of thing.
Don't know how a dime will help me....
Don
Old 05-02-2014, 08:08 PM
DStar5000's Avatar
Car is new to me. What is, is what I got!
Don
Old 05-02-2014, 08:09 PM
You best buy the rebuilt one. A new one, now, costs over $110. The last new one I purchased was only about $25.00.
The dime fix is only for when the soft like plugs are gone, but the parts are still there. If you have any missing parts. Then you will need to replace the unit. Or if the people selling the rebuilt ones will fix the one that you have.
Pictures always help when you are asking for help. So we know exactly what you are asking. I am only guessing that you have parts missing or the shaft that goes into the transmission is broken off. The cable itself will fit into the slot on the end of the drive unit and the shaft on the other end goes into the transmission.
Old 05-03-2014, 10:52 AM
DStar5000's Avatar
The part that I found missing is the slotted hex pin, at the top of this pic:
I guess someone had taken the speedo cable off before and lost it.
$60, with shipping, for something that probably doesn't cost $5?
Just makes me shake my head....
Don
Old 05-04-2014, 07:15 AM
Is there a plate/plug on the other end of the end of the part you have missing? If there isn't then that piece and the gear is missing and you will have to replace the whole unit. (the angle drive you have pictured it complete.)
If that piece is just broken off. You might be able to take the plug out and slide that part of the unit out. Then maybe you can be able to make a piece to fit, depending on your skills.
In the past, there was never any parts listed for the drive unit. We just replaced the unit.
Good luck, I believe you will have to just suck it up and purchase another drive unit.
Old 05-04-2014, 09:06 AM
DStar5000's Avatar
Not very easy to see up in that thing. It is still installed on the car. Nothing
else is missing....
It looks like a hex drive, slotted screwdriver bit!
Yea, $60 for a $5 PART. Makes sense to me!
Don
Old 05-04-2014, 02:48 PM
It has been a few years. However, I believe that the cable goes into the slotted end.
You will loose some trans gear grease. But I would pull the drive out and compare it to the picture of the one posted. If it is the same the you may have gotten the wrong cable.
Otherwise good luck.
Old 05-05-2014, 09:01 AM
Don
Don
It's a vintage Porsche not a bug.
Old 05-05-2014, 11:47 AM
DStar5000's Avatar
SO, I should just piss $50 down the drain in promotion of Old Porsche Snobbery?
Don
Old 05-05-2014, 07:08 PM
DStar5000's Avatar
Don't need to pull it out! What I CAN see is just the hole, where that slotted hex piece should be! And that would go into the cable correctly also.
Don
Old 05-05-2014, 07:10 PM
Then you have to buy a new or used one. Send it to VDO and see if they will fix it for you.
You quest yer Chester.
Old 05-06-2014, 08:56 AM
oldbusboy's Avatar
I have the same issue, but I bought the new angle drive.
The question I have is: How do I remove it?? There is no way I can get any kind of wrench in there to undo the hex nut around the drive.
To remove it do I remove the whole front transmission mount?
Trevor
Old 07-28-2018, 06:14 PM
WFBowen's Avatar
Trevor:
The angle drive is kept in by a locating bolt, circled in orange below. In the lower photo you'll see the arrow pointing to the hole which lines up with the pin bolt. You'll have to support the trans, then remove the crossmember mount. I've put a link to a good thread detailing removal and installation of the angle drive. Scroll down to see some additional photos which help explain how it mounts, etc. Link: 901 speedo drive gear Good luck, Bill
Old 07-30-2018, 08:59 PM
Does anyone know the part number for the washer and locating pin / bolt ?
Old 11-15-2021, 02:48 PM
cmpski's Avatar
If your going to keep your car long term I recommend you aquire a factory parts book like one of these depending on the year of your car. Other than the engine the 911 version works well also. The picture blowups are helpful for assembly also.
https://www.ebay.com/itm/265331777225?hash=item3dc7019ec9:g:49AAAOSwZ-FhURzq
https://www.ebay.com/itm/312450772857?_trkparms=ispr%3D1&hash=item48bf846f79:g:gHgAAOSwv~dhHX7n&amdata=enc%3AAQAGAAACsPYe5NmHp%252B2JMhMi7yxGiTJkP rKr5t53CooMSQt2orsSB0Xm7k0guzAysaIMfJcbBOn23zQAKc2 %252FedUP23UewP60zH6GkdntMUVSpvMQ7Qwo1Jr4x4LfilW9X xy%252F4J%252FMpQuPe6KpwdJ%252FTaEy9Uff6FX7yseaARF xLsbLtNtjT6ebWw%252BXfrbbBhIcexu1CnZ0InxvEbeFtJmB5 Rrx6bMkL4AYKNiVhqqu18zTLvHPTZCz7HUxlP5ilN7H6kI3Jk1 n3UCS2ug0q66c7d3Woqd4yEqB34OMElHC0znCVhDETu0HZjiuN CO2Hhwvpnpu1AYQHx3wBuV0rdtVxbwFQyTAkn2ZF%252FMcYAu T6PIIMJfO3oJwu6q32r2AmHRpeTNgOO2xo%252BXYIJ19QYrEz MUXrNVA6nPq5P%252Bz4AVyw6izA3MKJ3PPi55B3OLY%252BM9 n%252BsVZCO6H%252F6eSB9yOTy213xRT8%252Fh9F7%252BAT Dv5V7DA0o6nqzyEi6LBdYM50km%252FE0FnvysSiZYHQzzK4Xl eJrjxEkSyyBRaxSajMMfpW8l0I3c9qoT9pNo99zXxRn0Ot2sPZ 38N%252FM4crekucBKctWshwfp2sHJwm7TgPnuo6zrt3yYKteZ yLi7vTQqiTT5ekXpid%252BSxnlN3HUd7pC7F3MgEbToETWcbL XhJ%252BO0%252F0F%252BPpQTDam%252BddISzJa4FLnxm42S xAbY%252BV8hy%252BkLPjkb3yBhrtuYcWTSf2WAGpBNgCtwRK 0uyqnBX9oLQXv71kt9UTNPt0eIV3mg1bktGKe1f7AoopAgdHL3 Cf25CKkm33dZYOzMonpU3K9ygyrEpDdgbPKgQCYVhFiRmlopox uOJoCm54H5eFk8P9IemtmZv4nt0Ac64DeR3Bgq2cq7DErX33hy b60jy3r7rYXGMT0qtBodUOwyz37Jk864%253D%7Cclp%3A2334 524%7Ctkp%3ABFBM3uDjkqVf
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 11-16-2021, 06:35 AM
