| Registered Join Date: Oct 2003 Location: jax,fl
				 |  forgot to mark the wires
			i for got to mark the dizzy wires when i pulled the motor . so i have a red and a black one , so whats hot?    | ||
|  11-04-2003, 03:25 PM |
| Registered Join Date: Nov 2001 Location: Austin, TX
			red and black both go to coil.  i am assuming you have a pertronix, or there would just be a black i believe. red is hot or positive.
				__________________ 68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe" Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S | ||
|  11-04-2003, 04:17 PM |
			it's the wires from the car . i may have hooked them up in reverse and that would explane the smoke .
|  11-04-2003, 05:05 PM |
| Banned |
			This link will help you. Steve http://www.hillmanimages.com/912/nav_electrical.html There is a lot of info on this site www.ottosvenice.com | ||
|  11-04-2003, 06:22 PM |
			SMOKE?   uh..... from what...... Morrie
|  11-05-2003, 04:40 AM |
			from inside the dizzy
|  11-05-2003, 03:54 PM |
			Didyou have a pertronix or other type of pointless ignition?  If so, its toast....
|  11-05-2003, 04:49 PM |
			no it was the points i left the pertonix out till i got it running . i guess i'll get a test light !
|  11-05-2003, 06:05 PM |
			smoke from inside the disty......hmmmm.  Next thing I would suggest is to verify you now have your wiring correct and then do a test light based static timing test to see if the points are making/breaking.
|  11-06-2003, 04:35 AM |
| Registered Join Date: Oct 2001 Location: Arlington Heights, IL, USA
				 |  Petronix
			As I recall my Petronix instructions said never to leave the ignition switch on for long periods of time without the engine running which could damage (fry) the Petronix unit.  That's probaly where your smoke came from. When I do electrical troubleshooting with the ignition switch on I always disconnect the red wire from the ignition switch at the coil to deactivate the distributorand Pertronix unit. good luck! Ron D
				__________________ RonD 69912T | ||
|  11-06-2003, 05:06 AM |
			Hey Ron!  Have another cup of coffee buddy!    VW505 still had his points in....
|  11-06-2003, 05:20 AM |
			Morrie: Just trying to be helpful. A word of caution can save you from bundle of trouble. He does own a Pertronix unit. Do you disconnect your wire to the Dizzy???? Ron
|  11-06-2003, 08:30 AM |
			Was just kiddin Ron, trying to keep it light hearted  Yea, reversing the hookups on a pertronix will cook it in a hearbeat from what I am told. Too bad as a strategically placed diode would pop the fuse when power is reversed and save the Pertronix. Still thinkin of what could smoke in a disty with just points and condenser.... maybe the condenser? It is a capacitor, and if it is electrolytic like I guess, they don't take well to having polarity reversed. hmmmmm... any new developments vw505? Morr
|  11-06-2003, 08:44 AM |
				 |  Oil Blowby?
			Morrie: Could the smoke actually be oil vapor from the crank case. If the dist shaft O-Ring seal is gone or shot?? Or a grounded hot wire inside the dist? Ron
|  11-06-2003, 09:34 AM |
			maybe.... if oil is present then its a possibility.  A grounded hot wire that smoked should be detectable in a visual inspection. Morr
|  11-06-2003, 09:36 AM |
| Registered Join Date: Sep 2002 Location: Pac NW
			I had the same thing happen to me WAY back early last year before I had a pertronix.  Was adjusting the timing and must of grounded something and fried my condensor... lots of smoke and a rather toasty condensor wire.    $11 later for points and condensor and I was good to go...
				__________________ Troy '89 964 C4 '83 308 GTS QV '88 928 S4 | ||
|  11-06-2003, 11:22 AM |
			Sounds like Troy is on to it.....
|  11-06-2003, 11:27 AM |
			the green wire was pinched and grounding out  ! i am not installing the pertronics till every thing is sorted out . i have lots of wires that need new homes .
|  11-06-2003, 12:39 PM |
			Good for you, the first bug is fixed.  Be ready for more, its half the fun of an old car! Morrie
|  11-06-2003, 12:47 PM |
			ya to bad i am done playing till Dec. and my ship pull's back in .
|  11-06-2003, 01:09 PM |
