Porsche Crest Help Needed Fast PLeAse (due to difficulty in shifting gears)!!!!!
I currently own a right-hand drive, 5-speed Porsche 912 (1969) . And i have a gear shifting difficulty. 1st gear is difficult to engage, Reverse gear lockout not working. Can engage Reverse without moving lever to the extreme top left hand. The Gearbox is fully reconditioned by Maestro. Gear Linkage has been adjusted as per workshop manual. Is it due to a Faulty Gear Lever Assembly?????
Do you have a complete set of the gear lever assembly ???
Thanks!! for your help. Please reply As Soon As Possible.
Daniel Ling(Singapore)
Old 12-20-2003, 05:32 AM
Nicol4's Avatar
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
Try this link.
Chris Nicol
912e sold June 9,2002
Old 12-20-2003, 09:47 AM
Have you made sure the linkage in the tunnel is set right? It almost sounds like it is off by a notch or 2.
Craig
Old 12-20-2003, 04:20 PM
C. Clark's Avatar
It could need a bushing set.
Chas.
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 12-20-2003, 05:00 PM
It's your clutch,it needs replacing.You say you have trouble putting it into reverse and first gear.
If you only had trouble putting it into first gear, then it may be your tranny.
Art
Old 12-20-2003, 07:01 PM
Jim Smolka's Avatar
Take apart the shifter assembly. Something could be loose or broken
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 01-20-2004, 04:02 PM
