Wiring Problem
I have a bit of a problem with the wiring on a 1969 912.
The board in the engine bay is shown on the PET
Item 9 is present on the board and has a Bosch part 0 333 611 004
The PET describes this as 'PART NUMBER UNKNOWN' and my OPC has the same information.
A similar looking part is also shown on a 911 Board as a DASHPOT Relay.
There is also a Round Black Relay fitted to the board but this is not shown.
The only 912 Wiring diagrams I have are for an early 912 and then 72 on 911s.
There are a couple of questions:
Does anyone have the correct Diagram?
What is a Dashpot Relay?
Help Please
Old 07-26-2010, 07:07 AM
C. Clark's Avatar
Ask your question here, 912 Board
Chas.
356912911
Old 07-26-2010, 10:39 AM
I also have a 69 912 and the board in mine seems identical to yours. The round black relay goes in/on the hole that you can see at the lower left of your diagram.
I am not an expert but the item you describe is, I think, simply described as a relay on the Porsche parts diagram. Its part number is - again I think, not certain - 902 615 113 00.
Still with the non-expert disclaimer - a dashpot relay is as described by its name. It is a relay where the closing action is damped by a dashpot - a cylinder (usually) with oil in it and a piston that moves as the contacts close. Often used in an overload protection circuit.
Old 07-26-2010, 04:02 PM
