1966 - 912 - SOLD
msd ignition and generators
ok if you have a generator on your car and you want to use a msd capacitive discharge ignition don't use the new type of regulator from Bosch!!!!!
just installed my generator after being rebuilt and also replaced the voltage regulator. then i ran down the street with it. i got 2 miles then the generator melted, literally the leads from the commutator came un soldered and two bars from the com are missing. the new type regulators do not regulate current!!!! the msd ignition will draw as much current as it can generator only rated for 25 amps!!!! next thing is to go out to Emory's and get a alternator kit for my little beast
i was too tired to be pretty last night! |
![]() I would of done that first. Alternators is the only way to go, unless concurs |
1966 - 912 - SOLD
it looks like a good kit what are your thoughts of it?
Rod's insulation is real clean. They did a very good job on the alternator stand. I just would not consider using a generator again on a non concurs car. However, they are a little on the spendy side.
abit off center
Was you regulator a 20 or 25 amp. The early generators were 20 amp and if you don't match the regulator it will toast your generator. I have been running a msd for 8 years now.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
1966 - 912 - SOLD
it was stamped 25a- dont know what i was drawing. i plan to throw a amp clamp on the output of the alternator to see whatthe draw realy is. upon further investigation i found that the published draw for the msd is 1A pe 1000rpm, that still puts me under the rating for the generator.
the alternator kit is working great now. i am now able to run higher wattage lamps in my headlights.
