P Car Addict
klober23's Avatar
65 912 engine serial location / blank case?
Gents,
I just picked up an early 65 912. I do not see an engine serial number in the typical location below the generator. What's your thoughts? I am awaiting the COA from Porsche, but was curious on the early cars (65-66) if there was known cases of original engines with no engine serial? Is there another location they would have stamped it? Chances it's a factory blank case or a blank replacement from a past engine swap?
thanks in advance
RIP Grady Clay
Old 06-11-2015, 03:35 AM
The 3rd piece of the case with the serial number can be swapped around relatively easily. It is not really a true indication of an original engine, although it is used as such to gauge value. It could be nothing more than a replacement 3rd piece. Check the stamps on the top of the case halves to indicate at least an early engine type. There are stampings on the case halves that will date it exactly but the 3rd piece needs to be removed to see them.
Someone else may have but I have not heard of a 912 leaving the factory with a non-stamped 3rd piece as new.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 06-11-2015, 07:59 AM
If a complete new replacement engine was installed at the dealership, there will not be a engine number. Unless the dealership stamped it.
Old 06-11-2015, 09:01 AM
rapido356's Avatar
Or 2 letters before the number....kd if your engine was change by a PORSCHE dealer
Whell, i have a 65 engine without ID number, and the third piece is 69 date ! i think she was change and the original number never write !
So sorry for my poor US language
JLC
356 sold now for 66 kg sold now for 66 912 US import sold now for 69 912 barn find US import (never sold), in the 911 world with 3.0 CARRERA euro sond now and an US 79 SC sold now.....
Old 06-12-2015, 09:39 AM
Hi over there.
Pls. attach a photo of the generator indicating the place with missing numbers. I have the same "problem" with my 912 from 66. The possible explanation I got from Porsche-reg912 was that spare parts do not have numbers :-)
Old 07-23-2015, 02:15 PM
