914-6 front mounted cooler connection points?
Would you help?
I am looking for the correct way to plumb oil lines to a front mounted cooler. I am using a Mazda RX 7 cooler with the internal oil thermostat. My question is where exactly on the engine or oil tank do I make the connection to send the oil forward to the cooler and where exactly does the return line get connected to?
There is a thread already on the subject but by the end of the thread I was more confused than when I started reading it.
I think the oil flows from the 26MM bottom hole of the factory tank up to the forward
oil cooler and than returns from the cooler to the on board engine cooler.
Jim
71 914/4 to /6
73 914 restro
66 912 in pieces
Last edited by captjm; 12-15-2018 at 05:26 PM.. Reason: change in proposed flow path
Old 12-14-2018, 04:29 PM
Oil flows from the 26mm scavange line coming from the engine and instead of running to the tank it goes to the front cooler then back to the tank (side of tank)
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 12-19-2018, 05:34 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Arrow 914-6-GT oil cooler setup
here ya go
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 12-20-2018, 09:10 PM
