BobnJoz
Send a message via AIM to bobswei
Shift Linkage - Easy for you, not for me
I'm restoring my '74 and as I reassemble the shifter and linkage, it doesn't fit anymore. The main shift rod is hitting the motor mount cross bar. What is not correct on these photos? One photo is the correct way, the rest are mine.
Thanks for getting me straightened out.
Old 07-13-2019, 07:50 PM
My first question is, do you have it located correctly at the shifter?
Old 07-14-2019, 09:31 AM
And is the lock pin at the universal just before the firewall, is there one in there
Old 07-14-2019, 09:35 AM
BobnJoz
I did disconnect the shifter so I would have more free play on the shift rod. No, there's no pin there since I can't get it lined up straight to slide it in all the way.
It seems like, something is upside down or backwards. I keep looking at all the mounting points and all seems in the right place. I know it's something simple. Just not obvious.
Thanks for the input...
Old 07-14-2019, 10:55 AM
Ok, there are two locator pins. One at the trans and one before the firewall. What I do is remove the shifter so there is no known obstruction in the tunnel. I then line up the pins at the trans and before the firewall and screw them in tight. Then I reinsert the shifter onto the tunnel shift rod.
Old 07-14-2019, 11:05 AM
Ok, sorry. The tunnel shift rod can be a pain in the ass to get in the universal and lined up. That’s your problem.
Old 07-14-2019, 11:09 AM
What I do is get someone to hold the shift rod and move it with the selector towards the front of the car. Then you dont have much room but to use a small brass hammer and carefully tap the shift rod in the tunnel or reconnect the shifter to the tunnel rod, tighten and with the assistant holding the engine compartment rod try to move the shifter forward and it may push into the universal.
Old 07-14-2019, 11:14 AM
You see if you look at the firewall the tunnel rod has not engaged into the universal enough
Old 07-14-2019, 11:15 AM
Now, Dave would frown at me telling you this but, I’ve taken some vice grips and attached then on the shift rod just forward of the motor mount bar where it passes through the motor mount hole. That eliminates the need of an assistant. That way when you tap the tunnel shift rod into the universal it won’t move. Spray some wd40 into the point where the tunnel shift rod enters the universal. Use a small screwdriver to check to see through the pin hole if you get alignment
Old 07-14-2019, 11:23 AM
914 Geek
That's a pretty decent use of vise-grips. If you're worried about the finish of the bar, you can use a rag in the jaws of the vise-grip.
--DD
Old 07-14-2019, 01:51 PM
BobnJoz
OK, problem has been identified. A friend stopped by, who's a 914 guy, and we started looking at it. We decided to remove it and he sees that the rod is bent. Not sure how it got bent. Maybe when I was hammering out the pin for changing the bushings in the coupler. Anyway, I'll bend it back then follow jess p's procedures for adjustment. Yea, the vice grips sounds like a good idea.
Thanks for the responses and info for getting it sorted. Bob
Old 07-14-2019, 03:32 PM
