cycling has-been
Throttle valve housing - rebuild or replace?
Car is a 912 E
Throttle sticks at wide open throttle. First half of pedal travel is fine. As soon as I floor it, the throttle sticks, and pulling the pedal back up will not help. I removed the boot, sprayed/wiped down venturi with carb cleaner, trimmed the crimped end of the cable, and soaked with Kroil and PB Blaster. Even with the cable removed, I could still feel binding on the butterfly shaft. Anyone have a part number for the whole assembly - they don't look too expensive, and if replaced, I would always have a back-up ready to go. Thanks in advance, Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
cycling has-been
Hey Dave, are you there....
I think I have the PN ...039 133 062 D ? Thanks Bill K
914 Geek
That's what my copy of the PET says for the 914. I don't know if the 912E throttle body is any different. It looks the same, but that doesn't always mean it is identical.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
dr914 ***********
you will have to get yours rebuilt, 912e throttle bodies are impossible to find
cycling has-been
Right you are Dr.
The pn of the original is 022 133 067 A - not listed anywhere anymore. The 914 replacement unit (039 133 062 D) will probably bolt up, but I don't think the throttle venturis will match up. The oem unit is as follows: top - 58.82 mm bottom - 57.65 mm butterfly - 45 mm Bill K ![]() ![]()
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 08-05-2019 at 11:30 AM.. |
