cycling has-been
bkreigsr's Avatar
Throttle valve housing - rebuild or replace?
Car is a 912 E
Throttle sticks at wide open throttle. First half of pedal travel is fine. As soon as I floor it, the throttle sticks, and pulling the pedal back up will not help.
I removed the boot, sprayed/wiped down venturi with carb cleaner, trimmed the crimped end of the cable, and soaked with Kroil and PB Blaster. Even with the cable removed, I could still feel binding on the butterfly shaft.
Anyone have a part number for the whole assembly - they don't look too expensive, and if replaced, I would always have a back-up ready to go.
Thanks in advance,
Bill K
Old 07-31-2019, 11:00 AM
cycling has-been
bkreigsr's Avatar
Hey Dave, are you there....
I think I have the PN ...039 133 062 D ?
Bill K
Old 08-01-2019, 04:19 AM
914 Geek
That's what my copy of the PET says for the 914. I don't know if the 912E throttle body is any different. It looks the same, but that doesn't always mean it is identical.
--DD
Old 08-01-2019, 08:17 AM
dr914 ***********
you will have to get yours rebuilt, 912e throttle bodies are impossible to find
Originally Posted by bkreigsr View Post
Car is a 912 E
Thanks in advance,
Bill K
Old 08-01-2019, 11:48 AM
cycling has-been
bkreigsr's Avatar
Right you are Dr.
The pn of the original is 022 133 067 A - not listed anywhere anymore.
The 914 replacement unit (039 133 062 D) will probably bolt up, but I don't think the throttle venturis will match up.
The oem unit is as follows:
top - 58.82 mm
bottom - 57.65 mm
butterfly - 45 mm
Bill K
Old 08-05-2019, 11:13 AM
