Oil filter bracket gasket
I'm looking for a gasket that goes between the engine block and the oil filter bracket. Its a thin, plastic-like gasket and I can't find it at either Pelican or GPR. Any thoughts? Is that something I might find at a local VW shop?
-Tony
Tony ------------------- 70 914 EJ25 - Body by Karmann, Engine by Fuji Heavy Industries |
Have you tried calling PP? They usually have a lot of stuff not in the online catalog.
Jeff Keyzer 72 914 w/2056 built by Mark DeBernardi @ Original Customs Megasquirt with MSII upgrade |
if all else fails, buy some gasket material at local auto parts store (FLAPS) and cut your own. use base as template
Buy some loctite 518 Anerobic gasket eliminator and install the bracket without the gasket...thats what we do, never had one leak yet, but ALL THE OIL MUST BE totally removed from the surface
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
thanks! I think I'll give the loctite a try.
-Tony
That stuff works wonders......we even use it on oil pumps with no gasket!
