name another part for me please
Thanks for your help guys, mechanics. Anyone know what this part is drivers side in engine compartment mounted towards rear of car
Old 11-01-2019, 07:48 PM
914 Geek
Looks like a non-stock add-on. Possibly a starter relay.
--DD
Old 11-01-2019, 11:56 PM
I think you're right Dave the small white wire goes to the starter with the big black and red wires
Old 11-02-2019, 08:10 AM
I think that is the stock double relay found on 1.8 fuel injected models
Old 11-03-2019, 07:35 AM
914 Geek
Nope, there are no bolt-on terminals on the dual relay. There are also more wires going to it, I believe.
--DD
Old 11-03-2019, 02:37 PM
dr914 ***********
I agree with dave, looking at the big yellow wire, a add on starter booster relay made from a typical american Air conditioning relay
Old 11-04-2019, 12:38 PM
Thanks for the input..........my VW mechanic is going to put in for me the ford solenoid relay soon.
Old 11-04-2019, 01:59 PM
dr914 ***********
I would use the bosch wr1 instead
Old 11-05-2019, 11:55 AM
Really, I heard them say that the ford part was more water resistant
Old 11-05-2019, 04:17 PM
Ok so this is what I get NOW. I am reading 12.47 from the BIG black wire to the white and the same reading from the big black to the yellow, I am NOT getting a reading from the 1/4 inch nut connection to the big black wire............before I was jump starting from the two nut connections, now nothing, did I burn out my starter add on relay????????
Old 11-06-2019, 12:46 PM
Hello, void this last post about the add on starter relay, in all my inexperience and haste I forgot the plug in the wire from the add on starter relay to the starter, I can jump start it again and the add on starter relay is not bad. Might be the ignition switch will try some further testing.
Old 11-06-2019, 01:22 PM
