case splitting
building a 2.5 and trying to split my case, I have a case splitter , dead blow hammer, and it's stuck at the cam plug and fan pully somebody went happy with the pematex now what?
Did you get the nut behind the bottom of the tranny flange? Not trying to be a jerk, but I think you could break through the glue easily with those tools.
914 Geek
I once saw written instructions about separating the crankcase, to the effect of--
"Remove all the case through-bolts. Then go back and find the ones you missed. No, really, there are. Found them? Good--now go back again and find the other ones you missed. Trust me. OK, now go back a third time, there is still one more you missed." :lol: There are a couple that just love to hide. One back by the cam plug, which is covered by the flywheel when the engine is together, and one up front at the bottom of the motor. That one is usually covered with caked-on road grime. Go back and look for more case through-bolts. After you're sure you found them all, go back and look some more... --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I'm not trying to be a smart ass, but if you're starting to build a 2.5 and you're having a hard time splitting the case, you gotta a looooooong road ahead. Buy Jake's video, he explains tearing an T-4 down piece by piece.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
This is going to sound crude, but we used to always smack our cases apart. Once ALL the bolts are out, see the above very true post. Stuff rags in the piston holes and around the rods so they do not bang around. Grab the head studs on both sides of the case, lift the case about 8" from the concrete and smack it down a few times. Be sure you are absolutely flat on the concrete so you do not bust corners off the case. This jarring always loosened all the case goo that was used on the case halfes. If you are the least bit leerie about this, do not do it.
Sasquatch 1987 Porsche 944 1974 Porsche 914 "Don't retreat, reload." Sarah Palin |
The case should come apart easily. If it does not you have left bolts in place. There is a single bolt behind the flywheel that is overloked, as wel as the one that is between the pushrod tubes, in the center of the case.
I see cases ruined becasue of one bolt. My video does explain it directly.
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
914 Geek
Oh, rats! I forgot about the one in between the pushrod tubes!!
See, even in emails like this they're easy to overlook. --DD
my case split real easy just need two tools 18 lb hammer and 12 gauge wrench
just kidding could not resist
scott thacher 75 914 with 2.5 l 98 suby engine on the road |
you guys are always right,I looked at it about 15 times and never saw the bolt between the push rod tubes
I'm a type 1 guyalways willing to lisren and learn thanks!!
Ah, so a Sawsall is not the answer?
Ok, I'll leave the engine building to the engine builders.
Don Kiepert '73 Big Bore '02 GTI 1.8T Race a Porsche - There's more to life than left turns! |
If you have Jake's video or Tom Wilson's book, they both emphasize laying out and counting the case bolts. Until you have the full count, don't start opening the case. What are there? 24?, 27? It's a bunch.
where can I buy jake's vidio on type 4 rebuilds?
