trans drain plug stripped
Any tricks for removing a stripped transaxle drain/fill plug? Mine are starting to round-out. My 17mm allen wrench keeps slipping out. New plugs will be needed but gotta get the old ones out first. Any chance they are reverse threads?
I'm thinking a couple of spot welds to attach the plug and wrench. Then grind the welds off after removing the plugs. What kinda of metal are the plugs. |
They are right-hand (standard) thread and are made of steel.
The risk is that the trans case is magnesium, if you get it too hot with welding, well, that would be BAD! If enough of the plug is sticking out, you can try some vice grips on the outside. It's a longshot, but I have had it work before. |
Plugs are pretty much flush.
I'd be using a wire feed or arc welder. A couple of seconds of heat is all there is. But I'll have to find a 17hex socket. If I weld my allen wrench, I'll only get 1/4 turn before the end on the wrench hits something. Then I'm ****ed. |
914 Geek
You can try a chisel to turn the plug. I also know people who have drilled out the plugs. Not a fun job...
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
canna change law physics
On Mike95125's plugs, I applied heat to the case around the plug to loosen them. I'd try that before anything as drastic as welding.
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Puny Bird
Use a combo platter of the Dave’s and James' methods.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Re: trans drain plug stripped
Good luck Alex
1972 1.7L |
Try some impact on that puppy. Use an air hammer with a flat face and jar the hell out of the area around it, then give it a try.
If all else fails, use the hammer and chisel trick and be a butcher. I made a tool for a 1/2 impact by using a 17mm headed engine mount nut, welded onto an old socket, I have had it so long that it is starting to get worn out its self. Using it on an impact can give enough torque tyransfer to jar almost anything loose.
Jake Raby Owner, Raby's Aircooled Technology www.aircooledtechnology.com www.massivetype4.com |
I like the impact wrench idea. I just need to find a 17mm hex impact socket. Any ideas who sells 'em? Snap On, Matco, Craftsman/Sears, Harbor Freight?
I'll try heating up the case a little with a propane torch before using the impact wrench. |
You want to heat it quite a bit and then work immediately, since the tranny is full of fluid.
James
I know...I'll cut the end off my 17mm allen wrench and insert it into a 17mm impact socket. If it still slips, I'll weld the hex stub onto the plug and crank it out. I have no other use for my17mm hex and I can always buy another at Sears.
I had the same problem & tried the opposite of James' solution: I applied ice to the plug. Let it sit there a good long while. Not sure if it really worked or if I just convinced myself, but the plug came out.
Mark
Mark 1971 1.7l 914 |
