Another 'loose wire' goes where question?
This image is looking up under the dash at the front blower controls. There is a light brown wire and a dark brown wire attached at the circled connector they share. The light brown one is bare at the end and not connected anywhere. Any idea where that goes?
So far the front blower doesn't work. Not sure about the order of the three wires with the blue connectors either. None were connected. I put new ends on but wonder if there is a specific order? Fan speeds maybe...1,2,3??
As always, thanks in advance.
Tony G
2000 Boxster S
Old 06-18-2021, 06:24 AM
914 Geek
Check the wiring diagram for your 73. (In Haynes, also available in various places on-line.)
Component #30 is the fan switch, which is what you are referring to. It has seven wires that connect:
- Red/white (red with a white tracer stripe) that brings power to the switch when the key is on
- Black/blue, 2 connections that bring power to the lights inside the unit when the headlight switch is on
- Brown which is always grounded
- White/green which is ground for the fan on slow speed
- White/yellow which is ground for the fan on medium speed
- White which is ground for the fan on high speed
The fan operates by having power sent to it at all times when the key is on. The switch provides the ground, with more resistance for low speed and lower resistance for medium speed--and no resistance for the highest speed.
Your wiring has been messed with. Fortunately, it looks like whoever did that at least tried to follow the factory wiring for the most part. Those three white wires have aftermarket connectors on them, and rings are painted around the wires instead of stripes. Still, they look pretty close to yellow and green rings, so that's good, and they're in the right place for the fan grounds--all right next to each other.
I frankly can't tell what those remaining wires are plugged into. And I don't have time to dig through my stash to find my spare switch. Unfortunately, it looks like the dark-brown one has white rings painted on it, but there aren't any brown/white wires that connect to the switch on the diagram. Those are typically some sort of switched ground connection, BTW.
You can take an ohmmeter or a test light and check if either of those two mystery wires gets connected to one output wire when the switch is in the correct position for it. That would be the ground.
Good luck!
--DD
Old 06-20-2021, 02:11 PM
Thank you Dave. I’ll give it a go and see what I can find.
Is there a good way to test the blower up front? Can I put 12v to it and see if it turns? That would help sort the under dash wiring to know it should work.
Thanks again. Tony
Old 06-21-2021, 09:28 AM
914 Geek
The blower should have power while the key is on. It should show up through a red/white wire there.
The fan switch provides the ground, with various amounts of resistance.
So turn the key on and ground the appropriate connector on the blower and it should run.
--DD
Old 06-22-2021, 01:10 AM
Thanks again.
Old 06-22-2021, 03:20 AM
Hi Dave,
At the end of the day it was the blower motor that was no good. That loose wire is a ground and did not make a difference to running the blower. Grounded it anyway as I don't like loose wires. ;-)
Now I can get working on the radio and speakers to finish up the interior.
Thanks again!
Tony G
2000 Boxster S
Old 07-19-2021, 05:17 AM
