4 speed questions
I have 912 4 SPD transmission.
I'm having trouble sourcing the first gear dog teeth. Posting in the hope the 914 is the same ? Thanks lyndon |
914 Geek
I believe that they are the same, though I do not know for certain. The 912 used a "901" type transmission, which the 914 transmission is based on. The 914 synchro rings have "911" part number prefixes, so I think that means they will work.
So, the applications listed for the "gear teeth" (these look to be the dog teeth) in the Pelican catalog page for the 912 transmission parts also cross-references to the 914. NOTE: I am not sure if the type of dog-teeth used are the same as the five-speed's first gear set, or if they are the same as the five-speed's 2nd-5th gears! You might try pinging Doctor Evil over on the 914world BBS to see. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Will the car go backwards? If a 901 from a 912 is installed into a 914??
912 trans in a 914
I knew there was a simple answer, thank you for clarifying.
