Firewall Access to Engine Comp
Does anyone have a template for cutting an access panel thru the firewall to the engine compartment?
Thx George |
George, I've seen all different sizes big and small. I can measure mine if you would like. Mark
1974, 914-6 GT Tribute 2007 Cayman S 1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten. 2017 Golf Sportwagon 4motion Exclusive source for the 914 Umbrella and Service cover |
Here's a picture of a larger one. Also more on pbase 914-6 GT.
Thanks, but that is not going to be big enough
I think I'll heed the advice I got from a 914World member who advised me to make it big enough to remove the fan housing/alternator assembly through George |
Hi George, I'm not sure I would do that. Your engine/fire wall is a very important part of the structural integrity. If your worried about the removal of the fan housing to remove/service alternator you can modify the fan housing to accomplish that without engine removal. Just my 2cents. Best, Mark
914 Geek
If you are making a large hole, you might want to reinforce all around it. And definitely make it fireproof!! Remember that there's a reason it's called a "FIRE-wall".
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I'm using a decent thickness 18 gauge sheet metal plate on my six. Also a bit of thin weather stripping foam rubber around the perimeter to keep any vapors out. Disregard the extra "Bump" at the upper left corner...only needed for some custom engine compartment accessory that I've added.
Porsche builds the 21st century 9146 so easy...even a Cayman can do it ! |
