'74 914 2.0 AAR question
Suspect AAR valve no good, so I have a question: Is the power source that heats the air on start up to activate the valve 6 volt or 12 volt or something else so I can test the valve on the bench? Thanks for your help.
Old 11-10-2023, 05:36 AM
dr914 ***********
12 volt but will also close if the valve itself is hot
Old 11-10-2023, 01:02 PM
Where does the AAR lead typically connect? Is there any reason I can't get the 12V from the No. 15 side of the ignition coil?
Old 11-11-2023, 05:19 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The AAR coil connects to a wire in the ignition harness that goes back to the relay board and connects to the fuel pump power circuit. The wire gets +12V any time the fuel pump is running.
--DD
Old 11-12-2023, 11:21 AM
