Flat4ever's Avatar
Installing the MSD ignition in my carburated 2.0
Hello,
I just received my MSD kit (6A module, blaster 2 coil and tach adapter).
I would like to know the place you installed the electronic module. Engine compartment ? Rear Trunk ? Behind passenger seat ? An other place ?
Any comments (and pics) are welcome !
Old 06-14-2003, 02:01 PM
chrisreale's Avatar
here is a tech article that describes one guy's installation.
http://www.pelicanparts.com/techarticles/mult_MSD_install/mult_MSD_install.htm
I believe most people mount it to the back fire wall, as close to the dizy as possible to keep the wires short as possible
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 06-14-2003, 02:54 PM
John Rogers's Avatar
Keep the wires short is good, also heed the high voltage warnings and do not wrap the wires tightly together or you can get bleed through. Good luck
Old 06-14-2003, 06:29 PM
p914's Avatar
I put a Jacobs I.C.E. Pak on the firewall next to the battery. The electronic ignition is a great addition.
Old 06-14-2003, 10:51 PM
with the jacobs carry the correct style fuse in the glove box or it will turn into the most exspensive part you absolutely need.
kevin
here? not so much i think. high five!!!
Old 06-15-2003, 06:36 AM
p914's Avatar
The fuse is directly between the unit and the battery,in a holder of it's own all in the engine compartment. It's a standard fuse, not expensive. Very easy to install the ignition. Took about 35 minutes. Engine sure purrs when it is installed.
Old 06-15-2003, 09:27 AM
it's not the ceramic like the standard 914, but if it blows and the spare is elsewhere you the wsp will tell you to push it or tow it. what's your general location?
kevin
Old 06-15-2003, 09:33 AM
p914's Avatar
Vancouver. The Jacobs I.C.E. Pak can easily disconnect and run off the regular coil if there is no spare fuse available. So no tow necessary. Just reroute the wire to the original coil wire to the distributor. That's a good backup with the Jacobs. The original coil is passive and can be reengaged if problems occur with the new ignition system.
Old 06-15-2003, 10:35 AM
p914's Avatar
How is the car running now with the new ignition?
Old 06-16-2003, 04:38 PM
