5 Lug Conversion Front Rotors
Hi,
I am about to do a 5 lug conversion on my '76 2.0. I am going for the drilling option and tap out the holes to take the wheel bolts. The problem is I bought new front rotors so that everything started as new (as recommended) but the '76 rotors have the wheel centring rim which dosen't fit in the centre hole of the new wheels. It looks as though it could be machined off. I know you are all going to say that I should have gone for the earlier rotors, but will machining it off these ones cause any problems with strength etc (I hope that I am not the first to come across this problem). The rotors came from Germany so taking them back and changing them isn't really an option. The wheels are 6x16 and 7x16 Fuchs from a '79 911SC. Thanks for any help PJ |
Itf you have access to a lathe or mill - remove them - they're just there to make mounting the wheel easier.
"Inventor - Blue Flame 914 Seat Heater" "Yellow Rusty Cars Are Faster" _____________________________ '70 2.5 (I'll never finish it - Somewhere over the rainbow.....,) '73 2.0 (Just Not The Same) '74 2.0 (Heartless & Lungless) |
canna change law physics
I saw a very nice Mill, Lathe Drill combination for $565...(drool)
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Banned
Here try these guys they should be able to turn them for Alloys. Steve
http://www.bigboyztoys.co.uk/ |
Instead of going through the hassle of converting to a 5 lug bolt pattern, spend a few extra bucks and buy a Carrera front end. You'll thank yourself later.
Turn them for alloys.. That sounds very British, like 'check under the bonnet to see if it's earthed.'. M
I wish I had a dime for every penny I ever had. http://www.914club.com/bbs2/uploads/blog-1136350347.jpg |
Very british????????????
you can check for earths under the bonnet after filling up with petrol and packing your kit in the boot I guess!!!! ![]() Thanks for you help - I must say I am tempted to convert to the 911 suspension - will have to talk to the chief accountant (Mrs!!!) Thanks again PJ |
PJ UK - that was aimed at Steve Stromberg, a colonial rebel.
