This damage was caused by nothing more than an out of tune engine, or a mechanical failure somewhere up stream....Be it a starving carb or wacked out dizzy.
This can be avoided with good instrumentation. As for a conversion, the TIV can provide 160BHP and be driven without issues like this, if it is done right, with the right recipes. Jake Raby Raby's Aircooled Technology www.aircooledtechnology.com |
It was the butter, wasn't it? M
I wish I had a dime for every penny I ever had. http://www.914club.com/bbs2/uploads/blog-1136350347.jpg |
But, in the end, Jake is right. There is an isolated problem. Just haven't been absolutely sure of what it is. A few therories and a few improvments will eliminate most problematic sources. At this point, if I had to bet, I would say that: 1. The fuel pump was inadequate 2. The main jets were too small 3. The no. 1 main jet picked up a bit of debris in the float bowl and clogged. That's a lot to be/go wrong at once. Evidence shows that if the no. 1 piston hadn't burned, it would have been just a matter of time (short) that something else would have failed. |
While we were blowing engines "testing", we put a video camera and recorder in the car so we could watch the guages. At Willow, the only time the driver had a chance to read was on the straight unless he was being gunned down.
"Inventor - Blue Flame 914 Seat Heater" "Yellow Rusty Cars Are Faster" _____________________________ '70 2.5 (I'll never finish it - Somewhere over the rainbow.....,) '73 2.0 (Just Not The Same) '74 2.0 (Heartless & Lungless) |
Stay away from my Member
I've gotta chip in and agree with Milt and Ron...instrumentation isn't gonna do squat in a "test" environment like this. 125° track temps and pedal-on-the-floor speeds the whole lap.
I have been advised to get a 914-6 triple gauge in the main dash panel just to make it that much more feasible (split-second) to look at my instruments: I currently have VDO gauges in the radio area. At a buck-ten and higher you just don't seem to have time to stare at the dash much... Of course a dyno environment seems to make a whole lotta sense. Anybody know of a good, affordable dyno around here BTW? I need to do some serious carb and ignition tweaking one of these days. Sorry again about the meltdown Milt. Hopefully next time out will be cooler and less expensive/frustrating!
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
Guest
Posts: n/a
Chris; I just used a dyno shop in Reseda on Hart St. Strictly Dyno (818) 345-3121. $75 for three pulls with a printout of each.
Thanks Andy, that's not bad at all and pretty close to home too!
