non blinking blinker
I hate electrical gremlins. I have put together a new car, so far, so good, but the pass side turn signal isn't working. If the key is in the off position, and I turn the indicator lever, the turn signal lights light, but don't blink. If I turn the key on, off they go.
The drivers side works fine. When I turn on the hazards, the drivers side blinks but the pass side doesn't. Any ideas? thanks in advance as always. I am close to posting a pic, I just want it to be all super nice when I finally do. |
The light should stay on if the turn signal switch is off center and the key is off, early pre-computer safety checker. I'd guess it is the emergency switch failing. Good luck
I have been fortunate enough to never have really dealt with this stuff, where is the emergency switch?
I believe John's referring to your hazard switch.
I recently had some screwy turn signal issues caused by a bulb that wasn't happy in its socket. I switched the two front turn signal bulbs and presto! Problem gone. So try swapping left & right bulbs first, both front & rear, to see if that changes anything. Naturally, all contacts should be clean.
Mark 1971 1.7l 914 |
gotcha, I was thinking he meant the Ebrake switch. I put all new bulbs in yesterday and that didn't do it. But, I will try switching things around and hoping for some voodoo.
I took the car for a twisty mt drive tonight and I remember why I have one. Wow. I do have another hazard switch, I will try that too If anyone else has any ideas, dont be shy |
Thanks, that what I trying to remember to call it. If I remember corectly the turn signal voltage goes through the flasher switch? Try pulling it on and see what happens? When I had one go bad, it smoked!! Good luck.
