canna change law physics
red-beard's Avatar
Things I learned this weekend
not in any order:
When dropping a 6 with carbs - remove the carbs before dropping the engine (CV Clearance)
Removing the oil lines are a B*tch
If you properly drain the oil tank, the filter is drained too, unless you invert it
The Power washer is your friend. Dirt and grime are the enemy. Do not fear the power washer
Sean likes to finger paint with RTV
2 reasonable fit guys can lift a 911 engine into my jeep
Rubber mallets are a great learning tool for how hard you should hit things with them, because if you are too violent, it is self correcting
Wow! There is only 1 bolt holding the 6 to the car!!! It's a big bolt but still! It like to fall on the ground too.
Nitrile gloves are da bomb!
My neighbors my think I'm nuts when Sean and I start making monkey sounds at each other and waving wrenchs around...
Keep plenty of "shop towels" around for oil leaks and minor oil floods.
The best spot for the jack stand on the back of the 914/6 is under the rear trailing arm pivot. However, the driver side oil line drains in exactly this spot!
Did I mention removing the oils lines are a B*ITCH! They ARE!
The guy that fixed my rear suspension console is a thief. He fixed my existing one and stole my replacement.
Balancing the engine and tranny on a Jack stand is a PIA. I guess I'm going to buy the "tool"
Going to bed now....
James
James
Red-beard for President, 2020
Old 09-14-2003, 11:43 PM
Jim Smolka's Avatar
Sounds like a fun weekend
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 09-15-2003, 04:09 AM
mikester's Avatar
Send a message via AIM to mikester
Sounds satisfying.
-The Mikester
I heart Boobies
Old 09-15-2003, 05:46 AM
Toast's Avatar
Those damn carburators always seem to get in the way........
73 Yellow 2.0
86 Toyota 4X4
Old 09-15-2003, 10:03 AM
There is NO wiggle in this set-up. Bout 100 bucks, nowdays. ...
JPIII
Early Boxster
Old 09-15-2003, 10:56 AM
red-beard's Avatar
Well, my Jack stand only go so high....And I bought the big ones.
I guess I need to get a lift.
James
Old 09-15-2003, 10:59 AM
Here's and old thread. I hates jackstands.
Seat recovering
JPIII
Early Boxster
Old 09-15-2003, 11:29 AM
jkeyzer's Avatar
Wish I could be there to help. Sounds like you are having fun, James.
Jeff Keyzer
72 914 w/2056 built by Mark DeBernardi @ Original Customs
Megasquirt with MSII upgrade
Old 09-15-2003, 09:00 PM
