DuckRyder's Avatar
Send a message via AIM to DuckRyder
Porsche Crest Preparing a 914 for Autocross in SCCA CSP
Preparing a 914 for Autocross in SCCA – read much on search.
Afternoon board.
I’m hoping to have my 914 running and ready to go for the first autocross next year.
Due to my heat exchanger swap and lack of an air pump I’m going to be forced to run in CSP (C Street Prepared) where I can do quite a bit to the suspension short of metal bushings. (I will probably have a better chance here than in Miata stock anyway)
Anyway, keeping in mind that I want the car to be legal in class and it remains a street driven car how does this plan sound.
Long block rebuilt (bottom end stuff is on order from Pelican, heads are at Rimco) to stock specifications.
Weltmeister front and rear bars in place of stock (which size?)
Weltmeister springs (140 lb?)
Weltmeister torsion bars, hollow (size?)
Weltmeister camber plates.
Weltmeister poly bushings front and rear.
Bilstein’s
Stainless brake lines
Hawk HPS front pads
? Rear pads.
205/50/15 Hoosier A3S03
Factory 2.0 wheels (I have 10 of ‘em)
How bad is the massacre going to be? (I have run in the past and could place in the top 3 in class in DSP in a 318iS)
Did I miss anything?
Robert
1975 Porsche 914/4-2.0
1972 Ford F100 Ranger XLT
2006 Ducati Sport 1000
323i.net
RangerXLT.com
Old 11-18-2003, 01:47 PM
Do you wanna scare the Miatas or just have fun? Serious CSP Miatas are hard to scare.
JPIII
Early Boxster
Old 11-18-2003, 02:11 PM
DuckRyder's Avatar
True JP, I'm not out to win a national or even a divisional, but I'd rather not be dead last EVERY time.
Locally, CSP is a smaller class, most of the Miatas go from CS to SM(2?)
So I guess to answer your question is, Have some fun.
Robert
323i.net
RangerXLT.com
Old 11-18-2003, 02:15 PM
I auto-x my 63 Bug (on a IRS chassis) with the 2270 that is now in the 914. I was in SM class and I got creamed.
However, I was about the hit at the show since everyone thought it was the greatest to see that old bug sliding around, lifting the inside front wheel (not condusive for making turns, but quite the crowd-pleaser).
I had a blast.
I'll have a bigger blast in the 914, however... :P
Tom
Old 11-18-2003, 02:26 PM
914 Geek
If you're up against any serious Miatae or even CRXes or 80s-vintage Civics, you're hosed. See if you can fight for "Best of the Rest".
Other stuff you've left off the list:
Overbore by 0.5mm is legal. Arguably. Maybe even by 1mm...
Headers. Tangerine Racing for the best results, Kerry Hunter for the more budget-conscious.
Mix-and-match engine parts to get everything balanced as well as you can. I don't think you're allowed to take weight off to balance, but I'm not sure on that.
Oversize throttle body with cold-air intake and free-flow K&N style filter.
Tweak the FI to deal with the above changes.
7"x14" custom ultralight wheels, with 245-width Hoosiers. (I think that was the size.) Yes, you'll need flares.
22mm front torsion bars
200+ lb rear springs
22mm front sway bar
Limited slip differential (if legal, it might not be!) and small rear sway bar (if you can have the LSD).
Lighten everything you can.
Possibly a roll cage or bar to help stiffen up the chassis. Always run with the roof to help cut down a bit on the chassis flex.
As you can see, getting "serious" about Street-Prepared gets kinda crazy in a hurry...
--DD
Old 11-18-2003, 04:04 PM
John Rogers's Avatar
Do you have a copy of the rule book? If not I'd get one since the SCCA is "if it doesn't say you can do it, you can't". Can you mod the tranny such as close ratio gears, smaller ring/pinion or limited slip? If so do it as that will have a huge effect on time. If you can use spacers, try them so the car will be wider and corner better. Remove the front side marker lights so those slalom cones will not rip them off. Remove as much stuff as possible under the rules, I.E. less weight is faster. If you can use a roll cage, use one since the car is much stiffer with it. If you can use camber plates in front, use them for better alignment. Also solid top strut mounts would help if legal? If you can get a shift light so you do not have to watch the tach and can watch the course. Finally get a good alignment and corner balance for best handling. Good luck.
Old 11-18-2003, 04:29 PM
DuckRyder's Avatar
Porsche Crest
I do have a rule book.
Limited slip is legal. (Where would one get that for a 914 tranny)
Balanceing is legal, with the provision that it cannot be lightened.
Maximum overbore is 1.2mm (gross, no alowance wor wear)
Headers and carbs are legal (but my street car requirement means it keeps heat and FI) the internal engine must remain stock for all practical purposes.
Flares are legal, but this is too straight a car to cut for flares.
Camber plates are legal, so add the Weltmeister ones.
Robert
323i.net
RangerXLT.com
Old 11-18-2003, 04:51 PM
For a limited slip I'd use one of the "GT" which feels a litle better than the Quaiff. How about gear ratios?
Old 11-18-2003, 05:34 PM
DuckRyder's Avatar
Porsche Crest
If I am reading right, the ring and pinion and the ratios cannot be changed.
Robert
323i.net
RangerXLT.com
Old 11-18-2003, 05:41 PM
M. Hendrix's Avatar
R&P, 2 choices, ratios can be changed. Legal in your class?
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 11-18-2003, 05:54 PM
DuckRyder's Avatar
Can't be changed in CSP. The trans has to be a 914-4 trans. It can only be updated or back dated as an ASSY. Shift linkage is free as long as it is mechanical, and the clutch is free as long as it uses the factory crankshaft holes.
Old 11-18-2003, 06:04 PM
914 Geek
With skinny tires and the stock exhaust, you have just about completely taken yourself out of contention in CSP. I would suggest that you forget the rules, build the car you want, and run it in whatever class it falls into. You'll still have a whole ton of fun!
--DD
Old 11-19-2003, 08:57 AM
DuckRyder's Avatar
--DD
That is pretty much CSP since I am not going to put Air injection and 75 heat exchangers back on it, stock is out.
I would like to do what I can to optimize it within SCCA rules and my personal rules. (HEAT, FI, and no cutting it up for flares)
I might consider the header later on..........................Maybe
Robert
323i.net
RangerXLT.com
Old 11-19-2003, 04:02 PM
Send a message via AIM to John Kelly Send a message via Yahoo to John Kelly
Hi Robert,
You are probably not interested...but you don't have to cut for flares, and you don't have to weld, or use fiberglass:
http://allshops.org/cgi-bin/community/communityalbums.cgi?action=openalbum&albumid=9980138836765
John www.ghiaspecialties.com
Old 11-21-2003, 07:31 AM
grind weld build
sean_V8_914's Avatar
John, I really like that look. Did you do that? Is this difficult to learn? (metal stretching)
flesh heals, memories last forever!
73 Orange, CS #601
73 Rayco V8 glug, glug
69 911 w/82 turbo look on 275 35 18s (for sale)
Trek 6500+
Sean M!
Old 11-21-2003, 01:06 PM
The way John does it takes time....and talent.
For the rest of us there's this. .........
Just a hammer & dolly. The guts (stupidity?) to booger up a good paint job helps.
JPIII
Early Boxster
Old 11-21-2003, 01:55 PM
DuckRyder's Avatar
Porsche Crest
John and JP, both very good looking cars.
John is clearly and artist.
Robert
323i.net
RangerXLT.com
Old 11-21-2003, 06:47 PM
M. Hendrix's Avatar
...and JP's a cheap bastard.
PAINT PLEASE
M
Old 11-21-2003, 07:06 PM
DuckRyder's Avatar
Exclamation
Would now be a good time to mention that un topcoated primer absorbs water, and water and steel make...........................
But it is still a good looking car..................
Old 11-21-2003, 07:18 PM
Paint? I'm a good paint job away from having 30K into this ****box and you ain't seen nothin' yet. Tomorrow I go get some doors....primered, of course. Them shinny ones are too heavy
Maybe I'll do em' in red lead for contrast.
Ah, the censor strikes.......
JPIII
Early Boxster
Old 11-21-2003, 11:57 PM
