handyher's Avatar
Send a message via AIM to handyher Send a message via Yahoo to handyher
throttle switch testing
Need some help . am trying to test throttle switch and need to know if i should take cover off and apply leads to paths or should i put the leads where the connector goes? have directions for doing the adjustment but am not getting a reading any where. am i doing something wrong or is the switch hosed. did not test in car as it is 10 degrees today.
thanks
renee
71 914
65 fstbk mustang
97 "burb"
94 pic um up
Old 01-05-2004, 04:03 PM
914 Geek
You don't have to pull off the cover, just unplug the plug. I haven't tested a 1.7 switch, but the wiring diagrams say to look for a "14" and a "17" on the housing of the switch. Those should tell you which pins get shorted together to tell the ECU that the throttle is closed.
--DD
Old 01-05-2004, 04:41 PM
handyher's Avatar
thanks dave, cover came off whilst carring it in the house and out of cold.
renee
71 914
65 fstbk mustang
97 "burb"
94 pic um up
Old 01-05-2004, 05:36 PM
