914 pass. door question
I put a door on my 72 914 from a 74 or 75 914, the 74 door seems to be about a 1/4" longer?? did i do something in hanging the door? or are they just a little longer?
really doesnt matter anyways, i need anouther new window for the passangers side
so i am looking for a 72 914 door with good glass.. and good metal, doesnt matter what color cause the car is in grey primer right now anyways!
THankyou
Mike
Old 02-28-2000, 12:51 PM
the only thing you my have done wrong is reverse the hinge the door part go to the rear of the part on the car. If this is O.K. then the door should fit. If you did reverse this you would of had a HARD time with the bolts! There is a chance that the door you used has been reskined incorretly and is to long, or that something on you car has been incorretly repaired( Q-PANEL HINGES ECT.)
Old 03-05-2000, 03:13 PM
