cantdrv55's Avatar
newbie question re 5 lug wheels
What are the benefits of converting to 5 lug wheels? Is it only possible to upgrade to 911 brakes after the wheel conversion?
Old 03-15-2004, 11:00 PM
mike95125's Avatar
high performance 911 wheels, and yes brakes as well.
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 03-16-2004, 01:30 AM
914 Geek
There are, as yet, no decent ways to put 911 brakes on a 914 and keep the 914's four-lug pattern. So the only way to get 911 brakes is to swap to a 911 front suspension.
There is a much wider selection of decent-sized wheels of the right offset to fit a 914 in the 5x130mm bolt pattern than there is in the 4x130mm bolt pattern. Not too many places make Bug wheels any more (that's the other car that used 4x130mm), and those are pretty much all the wrong offset for our cars. But there are a whole lot of 911 wheels out there, and most of them fit pretty well.
--DD
Old 03-16-2004, 09:04 AM
AJS AJS is offline
What would be a goos source for a complete 911 front suspension? Been checking Ebay with no luck. I'm in SoCal. Any suggestions?
Old 03-16-2004, 11:18 AM
914 Geek
Check around for 911s at the local wrecking yards. If there's a specialty wreckers, check there. Aase used to be one, but they closed up shop. I don't know who's down there any more...
--DD
Old 03-16-2004, 01:21 PM
Acox914's Avatar
Send a message via AIM to Acox914
i got mine froma 911 guy on PP who was upgrading to SC supension...post a want to buy add on the 911 board!
-Aaron
"60% of the time, it works every time"
Old 03-16-2004, 05:17 PM
anthony's Avatar
You really only need the 911 struts/brakes/rotors. You can still use the 914 a-arms although most guys go all the way use the 911 a-arms because they have larger 19mm torsion bars as stock.
FWIW, this is not a cheap upgrade if you do it right. Starting pricing new rotors, new brake pads, new brake hoses, brake caliper rebuild kits, turbo tie rods, new ball joints, bearings, etc., etc. I mean if you are going to have your 30 year old suspension completely apart you might as well refresh it. Figure on $1500 plus the cost of wheels and tires.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 03-16-2004, 10:35 PM
cantdrv55's Avatar
Pretty expensive upgrade! BTW, nice car Anthony. Where were those snowy pics taken? Your location says Bay Area but the pics looks like NV.
Old 03-16-2004, 10:42 PM
anthony's Avatar
I bought the car in Reno and drove it over the pass in light snow on the way home.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 03-16-2004, 11:40 PM
Search my user name and "suspension upgrade or similar" and you'll find lots of info provided by members who helped with my 5 lug conversion last year. Lots of pics as well.
John
'73 914
(Renegade V8 conversion)
Old 03-17-2004, 01:39 AM
