froggy's Avatar
some stud
I am having a problem with my exhaust studs coming lose from the head. My question is would it be alright to tack weld them in there just to keep them from spinning out. If the threads are still good inside and on the stud it’s self? If not do you have and suggestions on what would remedy the problem.
"when I become president I will make all the straight roads curvy."
1970 1.7
2001 4.0 Ford Ranger for backup only.
Old 04-23-2004, 10:01 AM
skline's Avatar
I would not weld them in, that is only asking for trouble. Use loctight on them.
http://www.pelicanparts.com/gallery/skline
It's easier to get forgiveness than it is to get permission.
75 Slantnose V8
03 S-10 Extended cab stepside in Yellow
72 914 Parts car
Old 04-23-2004, 01:01 PM
mike mueller's Avatar
head is aluminum, stud is steel.......I'd pay money to see you weld the two together
you'll have to repair the threads in the head...use new studs as well.
'73 914, 1.7, with Boxster transmission in the future?
Old 04-23-2004, 02:50 PM
froggy's Avatar
Thanks for your replies, I figure I will just tap the holes a little bigger and find some studs with larger diameter threads. I didn’t figure the welding would work but it seemed and easy fix so I thought if someone had done it they would know and what better place to find out than here.
1970 1.7
Old 04-24-2004, 11:47 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
A little bigger, as in a little wider (1mm or 2mm), sure. A little deeper? Nope, bad idea. Too easy to poke through into the exhaust port... That's a Bad Thing.
--DD
Old 04-24-2004, 03:05 PM
I have 2.0 914-4 heads for my rebuild, but are missing the exhaust port studs, where can I get a complete set?
Old 01-01-2005, 07:27 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
The best exhaust studs are those for a VW rabbit diesel 1.6
They have a bell shape in the stud that works really nice to keep them from stripping out.
If you are going to used the 911 barrel nut you will need slightly shorter studs.
Old 01-01-2005, 08:36 AM
Administrator
Pelican can get you exhaust studs. Check all of the holes to make sure they're not stripped, and to see if they're the stock size or not.
--DD
Old 01-02-2005, 04:08 PM
