Member w/ Title Problems
Jason Porter's Avatar
talk to ya'll tomorrow
2023 Ford F-150 Platinum 5.0 Coyote FX4
2019 Toyota Sienna XLE AWD
Metal Building Erector, Recovering Porsche Guy
Old 04-29-2004, 05:28 PM
norustscott's Avatar
Jason,
Do you plan to seal the engine compartment? If you don't it will run hot. If you do, Then the louvers in the body are not large enough to supply air to the fan and the carbs... It will also run hot and possibly rich as the cooling fan robs air from the carbs. You will have to kick the deck lid open @ the top or run a convertible deck led with louvers or punch additional louvers in the decklid. I cut three large holes behind the tag to get more air to the engine. Just 2 cents worth. I bet it is fun!
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 04-29-2004, 07:25 PM
we never run into restrictive engine bays and negative effects with TIVs in bugs....
The engine is so heavily finned that it uses the cooling air very efficiently.
Jake Raby
Owner, Raby's Aircooled Technology
www.aircooledtechnology.com
www.massivetype4.com
Old 04-29-2004, 08:13 PM
The vents in a bug were designed for the cfm intake of a type one cooling fan and a single 32mm carb I just dont see....never mind.
Scott
1982 911 SC
1962 sunroof bug
Old 04-30-2004, 06:10 AM
My 66 beetle has ZERO vents in the decklid, and my 2613cc TIV cooled just fine with a DTM... That was 5 years before I bought the company.
Never seen an issue.. The engines ability to shed heat, has more to do with the equation than anything else... One given amount of airflow does alot more cooling if the heat is dissipated from the engine faster..
Not even in a Speedster replica do we see the issues. They have way less airflow than a beetle.
Jake Raby
Old 04-30-2004, 07:30 AM
I'm going to run extended deck lid hinges starting tomorrow, after my first oil change and valve adjustment.
Plus I've got a buddy who's going to make me a titanium heat shield for the engine compartment, just because of his interest in the project.
BTW Jake, thanks on the lifters! No problems at all up to this point...knock on wood!
Old 04-30-2004, 07:57 AM
So the 2613 uses no more CFM to pull @ 4000 rpms than a a stock carb...I am surprised that the vw engineers provide tha much head room in the air flow calculations...however, I can't argue with real world data.
Scott
1982 911 SC
1962 sunroof bug
Old 04-30-2004, 08:20 AM
Eddie Brown's Avatar
Here ya go Jason...
1996 BMW 740il
Auto Tech for German Dreams (Bakersfield, Ca)
Old 05-16-2004, 04:28 AM
