In the shop at Pelican
Jared at Pelican Parts's Avatar
swapping CA 1.7 Pistons for higher compression 1.7 pistons
Going to have the motor out in the near future, would like to get a bit more power. Was curious if I'd have to susbtansially have to re-adjust the pressure sensor in order to make the domed 1.7 pistons from non-CA cars work....
Old 06-14-2004, 09:16 AM
914 Geek
Check your parts listing. I believe that the same MPS was used for both the CA-spec EB motor, and the "everywhere else"-spec EA motor.
Though with all of the D-jet systems, you may be able to get things to run a bit better if you take the time to fiddle with the MPS. But you'll need a dyno with WBO2 capability, or a WBO2 meter of your own and a lot of road time.
--DD
Old 06-14-2004, 09:36 AM
