Decel or not to decel
I have a 1974 914-4 1.8L. The Haynes manual talks about a "DECEL" valve, at the right side of the engine compartment.
When I got the car I got a decel valve that wasn't installed. IS there a problem? |
OCD project capitan
So it its the stock L-jet system? I'm pretty sure that you need it, it keeps the fuel pressure from skyrocketing which would the injectors from injecting more fuel when you get off the petal.
Don Welch '73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper. |
The decel valve routes air around the throttle plate when closed while coasting. This air promotes secondary combustion and reduces CO and HC emissions.
Thanks guys--If you look at the first picture there is a "funky" three port "thing" where the Decel valve goes does this stay or is it replaced by the Decel valve???
That is a D-Jet decel valve in the top picture. If you have a 1.8 then go with the other one in the 2nd pic.
1974 914 2.0 D-Jet 2004 BMW R1150RT-P |
i think the smaller one in the upper pix is a '74 decel and the bigger one uninstalled is a '75
73 914 restoration project 73 914 2.0 CIS #80 74 914 1.8L L-jet 83 911SC |
OCD project capitan
My bad, not fuel but air. Long week (even though it was a 4 day one)
"upon further review..." whoops, in the top pix that could be the fuel pressure regulator. in the pix, it is located in the position of where the decel valve should be. the regulator is on the drivers side rear (towards rear of car) in a little mount off the engine sheet metal.
Thanks again guys--Now I have time to install the Decel valve--my clutch cable just broke--oh well, should have changed it when I had the car apart--hope I don't miss the summer driving season again!!!
I am almost positive that is a decel valve in the top pic, not a fuel pres. reg. But oh well, good luck.
75' 2.0 w Ljet "I like the way she doesn't move in the curve's... and then she let's go!" |
'Uh Uh' right back at ya. That is the decel valve for 1974, mine has one just like it (and the POS leaks, too). The pressure regulator is on the driver's side of the engine towards the rear, buried way down low. You can be certain that neither of the large, unclamped hoses going in and out of the decel valve in the picture carry high-pressure fuel.
1974 914/1.8 2005 BMW 530i 2008 GMC Acadia Last edited by Will98D; 06-05-2004 at 08:26 PM.. |
That is a decel valve. You can see the fuel supply from the right engine shelf running to the fuel rales. Visible also is the >30 year old plastic return fuel line. The decel valve uses 13mm vacum lines from the breather to the plenum with a 5mm vacum line to the plenum. To decel or not to decel is a much less important question than to replace fuel lines or not to replace. Forgive me, I was reading Shakespear with my son last night.
to clarify a taste, the top pic is for a 74' and the bottom pic is for a 75'....there were so many changes for these engines.
more info-.....the 1.7 and 2.0 also had a version of the top pic
The 1st picture is absolutly, without any dought a decel valve the FPR is on the left side rear under the air flow sensor, I to have a 74 1.8 L-Jet and just changed the FPR and removed the decel valve,
Remember the FPR has fuel lines going to it!! not vacuum lines like shown in the 1st picture.
Levi 74 1.8 FI 74 2.0 Carbs |
Car should run just fine without it unless you need a SMOG test.
Ken
Anything worth doing is worth doing in excess Every silver lining has a cloud Assume Nothing |
This has been flogged to death... wonder how long we can keep this string going?
1974 914/1.8 2005 BMW 530i 2008 GMC Acadia |
I'm almost positive its a decel valve..
