Problem with distributor?
Finally, I got my '73 2.0 fired again. But I notice the distributor shakes a lot when cold. It's kind of like swirl motion. What's the cause? I checked few time and make sure the cap is fit and tight. Also, the idle speed is above normal (1500rpm). I checked the TPS and it didn't help. Any advice?
Andy -'87 Carrera -'73 914 2.0 -'06 Frontier -'02 VW Golf TDI -'07 GT3 RS -'07 Top Kart KPV-4 |
Take the cap off, can you move the dizzy shaft back and forth? If so the dizzy needs to be rebushed as its worn out. Have it rebuilt or find a rebuilt one.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression) www.914Club.com My Gallery Page |
Thanks, Geoff. I'll take a look today.
If the whole distributor body is moving sounds like it's just not clamped down tight.
